sandoz
openelec does't start
Sun Sep 23, 2012 8:41 am
i have been running raspmbc for some days now, but it reboots xmbc at times, after scanning a dir or other tasks, so i wanted to switch to openelec
I wrote the image to the sd card, inserted it in the pi, but nothing happens. The green light flashes a couple of times and the red 1 is on, and thats all. The monitor says no input
Then i tried raspmbc again, no troubles at all
What am i doing wrong?
i also tried raspian, no problems also
also with berryterminal openelec doesn't run :roll: :roll:
elatllat
Re: openelec does't start
Thu Sep 27, 2012 10:12 am
both projects work on and off for me, (they are very beta)
SBC with 32GB RAM: https://hardkernel.com
FAQ : https://raspberrypi.stackexchange.com
Unanswered: https://www.raspberrypi.org/forums/search.php?search_id=unanswered
Cloudcentric
Thu Sep 27, 2012 11:59 am
Are you using the latest image R12014 (bottom of page) and is the SD Card a Class4 ?
http://openelec.thestateofme.com
http://wiki.openelec.tv/index.php?title ... spberry_Pi
Also do you use a 5V 1A PSU ?
I know everything about nothing"
Return to “Other”
