Ubuntu MATE 15.10 for Raspberry Pi 2
Posted: Thu Oct 22, 2015 4:54 pm
by Wimpy
I've just release Ubuntu MATE 15.10 for the Raspberry Pi 2.
This release is a significant improvement of 15.04. You can find out more an get the download from:
Here is a run down of the changes.
2015-10-22 - Ubuntu MATE 15.10 for Raspbery Pi 2 Final Release
  • Added OMXPlayer GUI.
  • Added YouTube Downloader.
  • Added fake-hwclock.
  • Added python-spidev and python3-spidev.
  • Added python-codebug-tether and python3-codebug-tether.
  • Added python-codebug-i2c-tether and python3-codebug-i2c-tether.
  • Added file system integrity checking on first boot.
  • Optimised first run of MATE Menu.
  • Optimised LibreOffice icons.
  • Reinstated oem-config, which has been patched for the Raspberry Pi 2. Now includes the Ubuntu MATE slideshow.
  • Fixed udev rules and groups for accessing spi.
  • Fixed Scratch, it now runs via a sudo wrapper. Simliar to how Raspbian does it except only Scratch can be executed with elevated privileges, not everything.
  • Removed Compiz.
2015-10-14 - Ubuntu MATE 15.10 for Raspbery Pi 2 Release Candidate
  • Fixed framebuffer so it now uses 32-bit colour depth.
  • Added Minecraft Pi Edition 0.1.1-4.
  • Added Scratch 20150916.
  • Added Sonic Pi 2.7.0-1.
  • Added essential Python 2.7.x and Python 3.4.x libraries.
  • Added raspi-gpio.
  • Added python-rpi.gpio and python3-rpi.gpio.
  • Added python-serial and python3-serial.
  • Added python-picamera and python3-picamera.
  • Added python-sense-hat and python3-sense-hat.
  • Added python-astropi and python3-astropi.
  • Added python-pygame and python3-pygame.
  • Added udev rules for gpio, input, i2c, spi, vchiq.
  • Added /usr/local/sbin/adduser.local hook to automatically add new users to the adm, gpio, i2c, input, spi and video groups.
  • Added openssh-server with first-boot host key regeneration.
  • Added graphical a utility to disable/enable the MATE desktop environment for easily creating a headless "server".
  • Updated to Linux 4.1.10. Now using the kernel, firmware and drivers from Raspberry Pi Foundation and includes rpi-update to easily update the kernel and firmware.
  • Updated /boot/config.txt so it is now fully documented.
  • Updated to raspi-copies-and-fills (high performance memcpy and memset) 0.5-1.
  • Updated to xserver-xorg-video-fbturbo (an accelerated x.org driver) 0~git.20151007.f9a6ed7.
  • Updated to omx-player 0.3.6~git20150912~d99bd86.
  • Updated /boot/config.txt so when HDMI is connected audio is sent over HDMI by default.
  • Enabled Plymouth to improve startup and shutdown performance.
  • Removed oem-config.
Re: Ubuntu MATE 15.10 for Raspberry Pi 2
Posted: Sun Oct 25, 2015 3:23 am
by wh7qq
I just loaded the .img file to an SD card and fired up the Raspi with it...easy to set up following the instructions and the result was the config process for Ubuntu...local, keyboard, user, etc. It was a a bit slow but not serious. Once the config was done, the OS loaded and seems to be surprisingly responsive. It was great fun to see firefox running so well on the $35 wonder. I really have just begun to evaluate but it is impressive so far. I need to get the i2c module loaded so that my RTC will work but amazed at the applications that are already loaded like guvcview. Congrats and keep up the good work!!
Posted: Mon Oct 26, 2015 9:14 am
by AndyWhittaker
Nice, thanks!
Donation on its way...
Andy
Posted: Mon Oct 26, 2015 2:27 pm
by Kratos
I hate to be a sore tooth, but I have a problem.
Here's what I did:
1. I downloaded the Ubuntu MATE 15.10 for raspberry pi 2 from the European CDN on this website: http://ubuntu-mate.org/raspberry-pi/
2. I unzipped it with no errors
3. I first tried writing it to an SD card with my pi by using:
sudo ddrescue -d -D --force ubuntu-mate-15.10-desktop-armhf-raspberry-pi-2.img /dev/sda
4. After the write was finished I shut my pi down.
5. I plugged the freshly written SD card into my pi and plugged my pi into power.
6. The yellow led flashes like its doing something, but the screen is black.
7. The monitor is sensing something plugged in, but I just have a blank screen.
8. I tried leaving it like that for an hour, but the blank screen remained.
Any ideas? Any help would be much appreciated. :ugeek:
NOTE: The yellow led does not blink or have a pattern. It flashes like its thinking (like a normal pi).
Kratos
Posted: Mon Oct 26, 2015 6:09 pm
by MartinGoose
Kratos wrote:I hate to be a sore tooth, but I have a problem.
Same problem here. Wrote the image twice on different PCs.
Posted: Mon Oct 26, 2015 8:08 pm
by neo2001
What type of Displays are you using?
I had problems with my DVI display because hdmi_drive was set to 2 per default in /boot/config.txt.
After setting it to hdmi_drive=1 everything worked fine again.
But I didn't got a black screen, only a slightly off center picture.
Posted: Tue Oct 27, 2015 12:00 am
by Kratos
I'm using a HDMI display.
Kratos
Posted: Tue Oct 27, 2015 8:00 am
by MartinGoose
neo2001 wrote:What type of Displays are you using?
Mine is a Samsung Syncmaster with DVI input. I will try again making the change you suggest.
Update:
Yes hdmi_drive=1 worked here :D
Posted: Tue Oct 27, 2015 11:55 am
by Kratos
GREAT!!! Now it works.
Here's how to fix it:
1. Plug your SD card into a computer
2. It should show up as PI_BOOT
3. Open PI_BOOT
4. Find and open the config.txt file
5. Change
hdmi_drive=2
to
hdmi_drive=1
6. Save the file and eject the SD card
7. It should be fixed!
All credit goes to neo2001 for pointing that out.
Kratos
Posted: Tue Oct 27, 2015 4:55 pm
by Kratos
EDIT: See this post for updated results:
viewtopic.php?f=35&t=124572
Now that I can see it, I have a question.
How do I install Kodi so it works? This is how I installed it:
sudo add-apt-repository ppa:team-xbmc/ppa
sudo apt-get update
sudo apt-get install kodi
Here'e my problem and what I did:
1. I double-clicked the desktop icon
2. The screen blanks, and about 30 seconds later, the screen comes back
3. Running from the terminal non-root I get:
someone@somewhere:~$ kodi
/usr/lib/kodi/kodi-xrandr: Failed to get size of gamma for output default
libEGL warning: DRI2: failed to authenticate
Segmentation fault (core dumped)
Crash report available at /home/someone/kodi_crashlog-20151027_164340.log
The part of the crash log that concerns us is this:
16:43:38 T:1875943424 WARNING: Visual 0x21 of the SDL window is not suitable, looking for another one...
16:43:38 T:1875943424   ERROR: Failed to determine egl config for visual info
16:43:38 T:1875943424   ERROR: Previous line repeats 236 times.
16:43:38 T:1875943424   ERROR: EGL/GLX Error: vInfo is NULL!
16:43:38 T:1875943424    INFO: GLES: Maximum texture width: 2048
16:43:38 T:1875943424   DEBUG: EGL_EXTENSIONS: EGL_KHR_get_all_proc_addresses EGL_KHR_gl_colorspace EGL_KHR_surfaceless_context EGL_MESA_configless_context
############### END LOG FILE ################
############ END Kodi CRASH LOG #############
Otherwise, great OS! It is a HUGE improvement from Ubuntu MATE 15.04. It is very responsive and easy to navigate. Thanks for all the help so far.
Kratos
Posted: Wed Oct 28, 2015 2:16 pm
by neo2001
Can't really help you with the Kodi error - maybe you have a better chance of finding an answer here:
http://forum.kodi.tv/forumdisplay.php?fid=166
But if you want to use the Pi exclusively for Kodi anyway, I definitely would recommend using OpenELEC because it comes already optimized for the Pi/Pi2.
Posted: Sun Nov 01, 2015 4:01 pm
by carriba
Great job! Just installed on 2 RPi 2 B devices and works like a charm.
Just having some problems in syncing the system time from the RTC chip DS3231. I'm working on it to find out why, see my other thread on this...
Posted: Sun Nov 01, 2015 4:16 pm
by exartemarte
I'm up to my elbows in stuff at the moment but I will certainly be giving this a try when I get a moment. I use Linux Mint + MATE on both my PC and my laptop: it's an environment I like and am familiar with.
Posted: Mon Nov 02, 2015 7:44 am
by carriba
In case you want to access the UbuntuMate workstation with a VNC client here the steps:
1) On the shell prompt, type: sudo apt-get install tightvncserver
2) With you favorite text editor,create a text file "/etc/lightdm/lightdm.conf" with the following contents:
[VNCServer]
enabled=true
port=5900
width=1360
height=768
depth=16
The value of width and height describes the window resolution when connecting with a VNC client. Other working resolutions are possible with: 800x600, 1024x768, 1152x854, 1280x768, 1280x800, 1280x960, 1280x1024, 1400x1050, 1440x900, 1600x1200, 1680x1050, 1792x1344, 1856x1392, 1920x1200, 1920x1220, 2560x1600.
3) On the shell prompt, type: sudo /etc/init.d/lightdm restart
4) Then use your favourite VNC client, and type as target host i.e. "mypi.local" without precising any port number.
Posted: Fri Nov 20, 2015 10:37 am
by carloab
Hello all,
I too am having grief with the display on Ubuntu 15.10. Upon first boot, the display got shifted about a quarter of a screen width to the right and the rightmost quarter is not visible. I tried modifying various parameters in /boot/config.txt but have not managed to solve the problem.
Any ideas and help will be much appreciated.
Carlo
Posted: Sun Nov 22, 2015 1:47 pm
by Kratos
Try adding this to your /boot/config.txt file:
disable_overscan=1
Or, try messing with the display parameters:
overscan_left=24, overscan_right=24,
overscan_top=24, overscan_bottom=24
Kratos
Posted: Sun Nov 22, 2015 2:29 pm
by DougieLawson
Kratos wrote:Try adding this to your /boot/config.txt file:
disable_overscan=1
Kratos
Or simply rip all of those parameters out and let your RPi and your TV negotiate their best possible display resolution.
Posted: Sun Nov 22, 2015 6:52 pm
by carloab
Thanks for all your help. Disable_overscan=1 did the trick. :)
Posted: Thu Nov 26, 2015 10:36 am
by Fidelius
DougieLawson wrote:Or simply rip all of those parameters out and let your RPi and your TV negotiate their best possible display resolution.
Yes, this worked fine for me and a DVI monitor connected with the Pi via a HDMI to DVI cable:
I had to comment out all lines, otherwise black monitor. So now because of video applications there's only one line in the /boot/config.txt file:
gpu_mem=128
By the way, Ubuntu Mate 15.04 for the Pi² had a working config.txt (also commented out, I think) but just with Ubuntu Mate 15.10 for the Pi² the config.txt didn't work for my monitor and the other posters here.
Posted: Thu Nov 26, 2015 12:26 pm
by DougieLawson
My view with config.txt is that I only add things that are needed to make my RPi work. I don't add parms just because I can.
The most complex config is on my RPi that has the camera and an IR receiver
dtparam=i2c=on,spi=on
dtoverlay=lirc-rpi,gpio_in_pin=23,gpio_in_pull=high
dtoverlay=sdhost
gpu_mem=128
start_x=1
Posted: Wed Dec 09, 2015 6:18 am
by cjan
did not familiar with mate, which is Synaptics package name? and where can find a way to add nonfree distro, thanks.
Posted: Thu Dec 17, 2015 11:42 am
by Rocky Bennett
I am new to this whole Raspberry Pi thing, and to computers in general, but this is the OS that I am most excited about using. I have been playing around with Raspbian, and I have already downloaded Ubuntu 15.10, so I am ready to install it. I hope I do everything right.
Posted: Fri Dec 18, 2015 11:53 pm
by Rocky Bennett
I have been trying unsuccessfully to run Ubuntu Mate 15.10 on my Pi 2 and I can not get it to install. I am still trying.
Posted: Sat Dec 19, 2015 1:06 pm
by Kratos
What's not working?
Kratos
