Liber
Contact: ICQ
Hama "RF 2200" Set:Wireless Keyboard and Mouse
Tue May 28, 2013 12:36 pm
I wanted to try the latest RISC OS but my mouse does not work. If I use Raspbian, my mouse works perfectly. Any help is appreciated.
GavinW
Re: Hama "RF 2200" Set:Wireless Keyboard and Mouse
Tue May 28, 2013 12:51 pm
Are you using both USB ports on the RPi with RISC OS? I have a USB hub connected to one of them. When the keyboard/mouse wireless stick is inserted into the other USB port I find that mouseclicks go missing. When it is inserted into a port on the hub (so that only one USB port on the raspberry pi is being used) the mouseclicks all get through OK.
otium negare negotium vanum
thradtke
Tue May 28, 2013 1:50 pm
Have a look here: http://www.raspberrypi.org/phpBB3/viewt ... 55&t=22700
I gave up on my Hama wireless desktop.
Rocket Scientist.
Liber
Contact: ICQ
Tue May 28, 2013 5:41 pm
Thank you both of you for posts ;)
GavinW:
I am using only one USB port. It means, I could try your solution. Do you use a common USB hub or some kind of self powered USB hub ?
thradtke:
You saved me many sleepless nights :D If GavinW's solution does not help me, I will not waste my time with finding of another solution.
GavinW
Tue May 28, 2013 7:32 pm
I use a powered hub, an "Eminent" EM1107 7-port hub. I use a 2-into-1 USB connector from it to power the Raspberry Pi. Switching the Raspberry Pi on/off is done by plugging/unplugging the power lead for the hub. The hub is a compact hollow square with 5 ports plus power and USB-in on the outside and 2 swivelling ports on the inside of the square. Putting the wireless stick in a swivelled port means it sticks up in the air; whether that actually gives a more unobstructed signal I am not sure, but I like to think so.
Liber
Contact: ICQ
Wed May 29, 2013 5:15 am
Precise solution. It seems to be nice "toy". I am going to try RISC OS with my old wired mouse. If I find RISC useful, I will buy this hub. Thank you for your advice.
Return to “RISCOS”
