penpen
Risc OS + Samba
Sat May 04, 2013 12:49 am
Hey,
I was trying to install Samba for Risc OS (http://sourceforge.net/projects/riscossmbserver/)
But When i Double click the archive I get the error, that the software is not 32 bit compatible or something.
Does anyone have a detailed description on how to install Samba on Risc OS ?
~penpen
mahjongg
Re: Risc OS + Samba
Sat May 04, 2013 10:01 pm
its a version for a much older (10 year older) revision of the ARM processor, without re-compiling for the current ARM processor it will never work, unless you can run an emulator on RiscOS to emulate the older processor.
penpen
Re: Risc OS + Samba
Sat May 04, 2013 11:57 pm
Ah that must be the problem : x..
Is there another way to get samba running though ?
Recompiling sounds like alot of work.. Guess it wont be just "load sources and click compile".. So maybe I'll switch to debian. hmmn
AMcS
Re: Risc OS + Samba
Sun May 05, 2013 12:26 am
penpen wrote:Ah that must be the problem : x..
Depends on the exact error that was given (I thought 0.08 was supposed to be 32bitted...)
There were two alternative releases of version 0.08 - one from sourceforge (the one you found) and another from Thomas Milnius (http://www.gag.de/software/smbserver/). I downloaded this and put it on the Pi and it started without complaining. However I am not in a position to test it (have no other computer near for testing), so it might be another alternative.
Return to “RISCOS”
