Markodius
using CTorrent
Sat Feb 23, 2013 3:06 pm
Hi guys. I thought I'd have a ook at the torrent application but when i run it i get 'Path.!Run not found'. I've tried removing and installing it again but no joy. What am I missing?
“In the modern age, to call a man unelectable means he cannot be bought”
SEDev
Re: using CTorrent
Sun Feb 24, 2013 1:12 pm
Markodius wrote:Hi guys. I thought I'd have a ook at the torrent application but when i run it i get 'Path.!Run not found'.
CTorrent can only be used from the command line, you can't run it as a desktop application. It therefore has no !Run file, only a !Boot file that sets up the command alias 'ctorrent'. You then use 'ctorrent [options]' on the command line or in a TaskWindow. The options are described in the accompanying UserGuide. HTH
Markodius
Re: using CTorrent
Sun Feb 24, 2013 3:43 pm
:o Thanks SEDev, that explains it all really :roll:
Return to “RISCOS”
