RISC OS Composite Output?
Posted: Sun Nov 25, 2018 9:31 pm
by FreezeTile
Does anyone know how to get RISC OS to output video through the 3.5mm AV jack? I'd use a HDMI to AV converter, but I'm hoping to get all the cables into a relatively small case, so the less space used up the better. Thanks!
Re: RISC OS Composite Output?
Posted: Sun Nov 25, 2018 9:49 pm
by DavidS
Simple, do not hook up HDMI at all.
Also check your config.txt, if it has the line:
hdmi_force_hotplug=1
remove that line, as that would make the Pi think that HDMI is plugged in.
Posted: Sun Nov 25, 2018 10:13 pm
by FreezeTile
I've got it working now, thanks! :-D
