FreezeTile
RISC OS Composite Output?
Sun Nov 25, 2018 9:31 pm
Does anyone know how to get RISC OS to output video through the 3.5mm AV jack? I'd use a HDMI to AV converter, but I'm hoping to get all the cables into a relatively small case, so the less space used up the better. Thanks!
DavidS
Re: RISC OS Composite Output?
Sun Nov 25, 2018 9:49 pm
Simple, do not hook up HDMI at all.
Also check your config.txt, if it has the line:
hdmi_force_hotplug=1
remove that line, as that would make the Pi think that HDMI is plugged in.
The Raspberry Pi is an ARM computer, that runs many Operating Systems, including Linux, RISC OS, BSD, Pi64, CP/M as well as many more.
Soon to add AROS to the list of operating systems.
FreezeTile
Sun Nov 25, 2018 10:13 pm
I've got it working now, thanks! :-D
Return to “RISCOS”
