FreezeTile
RISC OS Composite Output?
Sun Nov 25, 2018 9:31 pm
Does anyone know how to get RISC OS to output video through the 3.5mm AV jack? I'd use a HDMI to AV converter, but I'm hoping to get all the cables into a relatively small case, so the less space used up the better. Thanks!
DavidS
Re: RISC OS Composite Output?
Sun Nov 25, 2018 9:49 pm
Simple, do not hook up HDMI at all.
Also check your config.txt, if it has the line:
hdmi_force_hotplug=1
remove that line, as that would make the Pi think that HDMI is plugged in.
RPi = Way for me to have fun and save power.
100% Off Grid.
Household TTL Electricity Usage = 1.4KW/h per day.
500W Solar System, produces 2.8KW/h per day average.
FreezeTile
Sun Nov 25, 2018 10:13 pm
I've got it working now, thanks! :-D
Return to “RISCOS”
