jewelie
NOOBS Lite 2.7.0 Pi 2 RISCOS Blank Screen No Activity
Fri Mar 30, 2018 2:43 am
Hi all
Just been giving NOOBS Lite 2.7.0 a go on my old Pi 2. Normally go straight to Raspbian but thought I'd give a few other OSs a try.
After installing via NOOBS, RISCOS won't boot- after starting it via the NOOBS OS selection screen I just get a blank screen and no activity on the LEDs.
It looks like the distro NOOBS Lite 2.7.0 is downloading is pretty old: http://downloads.raspberrypi.org/riscos_1760/RISC_OS.xz 2015-02-17
( Yes, I imagine downloading an image direct and installing it would probably work, but if it's actually a bug I'd like to do my bit and report it to the appropriate place given NOOBS is supposed to be for newbies and ought to just-work™ ;) )
Julie
Xxx
procount
Re: NOOBS Lite 2.7.0 Pi 2 RISCOS Blank Screen No Activity
Fri Mar 30, 2018 9:13 am
Try the earlier noobs v2.4. The new firmware on noobs2.7 for the 3b+ has some problems with oses with older firmware.
jewelie
Fri Mar 30, 2018 10:05 am
Hiya
Thanks for replying.
No doubt that would work, or simply dd'ing a recent RISC OS image to the card...
... but I'm not interested in just getting it working for me. ;) It's coming up on NOOBS Lite 2.7.0 on a Pi 2 (not 3 B+) so, assuming it's not my configuration and won't work for anyone else either, either it ought to "just work" (at least boot) or not be on that list until it does. So, how do I get that to change?
Julie
Xxx
procount
Fri Mar 30, 2018 11:08 am
Not easy to prevent it for noobs 2.7 without preventing it for noobs 2.4 or pinn.
We are in a transition period unfortunately.
My advice for anyone not using a 3B+ is to use noobs 2.4 or pinn 2.4.5f.
Pinn 2.5.2a might work as it attempts to upgrade the firmware but I've not been able to test it with all the OSes. Most work but the odd one still doesn't.
I'm hoping to fix it for all OSes in the next versiom of Pinn.
jewelie
Fri Mar 30, 2018 4:38 pm
Fair enough. Thanks for the information!
procount
Thu Apr 05, 2018 11:52 am
PINN 2.5.4 has just been released which restores the ability to install RiscOS and all other OSes on models prior to the RPi3B+.
ShiftPlusOne
Thu Apr 05, 2018 12:15 pm
By reverting bootcode.bin to the version prior to the breaking commit?
procount
Thu Apr 05, 2018 12:40 pm
Yes. Seems to work. Or it can keep the latest firmware and try to upgrade the OS firmware to match.
Return to “RISCOS”
