webshaker
Bundle of questions before starting
Tue Jan 02, 2018 10:32 am
Hi.
I'll have to start a new project and I like to have information about the RiscOS possibilty before choosing the OS.
I have had an Archimedes few years ago and I like this computer, so if I can use the BBC basic one time again it could be cool.
My main question are:
1 - Do the BBC basic still allow to switch to assembly. And if Yes, does the neon instructions are allowed ?
2 - Is it possible to draw on the DSI device AND hdmi device simultaneously
3 - How many second are needed to boot a Raspberry Pi with risc OS. I remember my Archimedes boots so fast.
Thank's
Etienne
webshaker
Re: Bundle of questions before starting
Tue Jan 02, 2018 1:06 pm
In fact this in not a DSI device but a LCD 40 pins device.
thank's
Burngate
Tue Jan 02, 2018 5:18 pm
Yes, you can still use assembler code. No idea about neon, as I've not needed it.
Try it and see.
Go to https://www.riscosopen.org/content/ for more info, specifically https://www.riscosopen.org/wiki/documen ... 0Pi%20port.
dfeugey
Wed Jan 03, 2018 8:16 am
BBC Basic's assembler is pretty complete. And there is now a version of BBC Basic with VFP support.
The system boots in around 20 seconds. Much less with a smaller Boot sequence. And in no time in command line mode.
Dual screen: not sure...
RISC OS FR - All RISC OS, in french (but not only)
http://www.riscos.fr/
DavidS
Sun Sep 09, 2018 6:39 pm
Yes it does. Same as always.
And the current version supports VFP and NEON instructions.
i do not know of anyone that has ever tried that. i am not even sure how one would go about it.
Is there a way to do so in other OS's on the RPi?
Depends on what is in your boot sequence. Anywhere from 7 seconds (for how i have mine) to about 20 seconds (for how it is configured when you get it).
Thank's
Etienne
I just hope this helps.
RPi = The best ARM based RISC OS computer around
More than 95% of posts made from RISC OS on RPi 1B/1B+ computers. Most of the rest from RISC OS on RPi 2B/3B/3B+ computers
Return to “RISCOS”
