MarkyV
RPCEmu on RPi
Mon Oct 16, 2017 8:26 pm
Hi Guys,
I'm trying to get RPCEmu running Riscos 3.1 on my RPi but having downloaded the Ubuntu source and installed the liballegro lib and tried to run the configure before make - it reports "checking for CPU... configure: error: Unsupported CPU." - Before I start chasing my tail - am I trying to compile the wrong thing?
Cheers,
Mark
My RaspberryPi Blog: http://thepimaker.online
MarkyV
Re: RPCEmu on RPi
Tue Oct 17, 2017 6:10 pm
Ok - found out who the numpty is - myself :) - lesson of the day - when configuring the build or RPCEmu for RPi do not include the --enable-dynarec option - obvious really :D
I now have ArcVenture running on Raspberry Pi! Yay! ... no seriously ... YAY!
Mark
mahjongg
Re: RPCEmu on RPi
Tue Oct 17, 2017 10:48 pm
Why are you emulating RiscOS (I assume running on Raspbian?) when the true RiscOS also runs on the RPI?
MarkyV
Re: RPCEmu on RPi
Fri Nov 10, 2017 7:28 pm
Unfortunately tests of the old software have not been successful on modern RISCOS - 16bit modules and screen modes being the main problems.
dfeugey
Re: RPCEmu on RPi
Mon Nov 13, 2017 7:03 am
16bit modules
With Aemulor (soon free on the Pi), it should not be a problem.
That's very easy to add custom modes on the Pi.
RISC OS FR - All RISC OS, in french (but not only)
http://www.riscos.fr/
DavidS
Re: RPCEmu on RPi
Sun Sep 09, 2018 6:22 pm
MarkyV wrote: Unfortunately tests of the old software have not been successful on modern RISCOS - 16bit modules and screen modes being the main problems.
I assume you mean software that uses 26 bit R15, that is the only addressing change that has come to pass in 32 bit ARM.
You can run most of the older software on native RISC OS using Aemulator:
http://sendiri.co.uk/#aemulor
The Raspberry Pi is an ARM computer, that runs many Operating Systems, including Linux, RISC OS, BSD, Pi64, CP/M as well as many more.
Soon to add AROS to the list of operating systems.
Return to “RISCOS”
