Changing hostname
Posted: Wed Mar 02, 2016 3:02 pm
by Markodius
Hi, how can I change the hostname of my RISC loaded RPi? I've tried doing !Configure/Network/Internet/Hostnames and replacing the default 'RISCOSpi' and typing in something else and clicking [SET] and [SAVE] and then restarting. The field retains the information I type into it even after a reboot but the hostname as seen on the network does not change from the default. Doubtless I am missing something but what is that thing? Pleeeease!
Re: Changing hostname
Posted: Wed Mar 02, 2016 3:35 pm
by brekee12
try:
sudo raspi-config
in menu 8 / A2 Hostname setting for network.
Hope this helps!
Posted: Wed Mar 02, 2016 3:37 pm
by rpdom
brekee12 wrote:Hope this helps!
Markodius mention RISCOS, not Raspbian, so probably not.
Posted: Wed Mar 02, 2016 3:47 pm
by Markodius
Hi and thanks for getting back to me Brekee12
'sudo raspi-config' gives me 'file not found' in the RISCOS CLI although it works just fine under Raspbian. I see there is possibly an installable package that will allow booting to Linux.. is that a requirement to running raspi-config under RISCOS? :/
Posted: Wed Mar 02, 2016 3:55 pm
by RaTTuS
changing the hostname in raspbian will not affect the RISCOS end of things
Posted: Wed Mar 02, 2016 5:17 pm
by Markodius
RaTTuS wrote:changing the hostname in raspbian will not affect the RISCOS end of things
Thanks RaTTuS, you've diverted me from the path to madness.
Posted: Wed Mar 02, 2016 7:09 pm
by Markodius
Hmm, odd. Changing hostname through the RISCOS interface has now worked but I'm not sure why. The only thing I did was to power down the Pi B+ and unship all cables (purely by chance as I had mis-inserted the micro SD card and needed to fish it out of the case after taking a look at the active partition on another machine). I'm tempted to say that the power needs to be cycled to assert a new hostname. Time will tell..
Posted: Wed Mar 02, 2016 7:45 pm
by Markodius
Hmm, very odd. I thought maybe it was the router, but that rebooted (as it often does) before my very eyes and no change. I removed the IP address reservation and rebooted. No change. Once again I removed all cables and the sd card and phaffed around for a while and hey presto! New hostname has asserted. I'm now tempted but wary of saying the power needs to be interrupted for a duration of some minutes to discharge all capacitance.
