Making a wifi bridge so risc os can work any where in house
Posted: Sun Jan 17, 2016 9:55 pm
by stylx
okay you have old laptop/netbook laying house if it runs linux go to network connection and under the ethernet tab on Ipv4 setting
under method select ( shared to other computer ) save and apply it reboot
now just connect a ehernet cable from the pi to the laptop/note book.
now you should be able to use risco os any where in the house
Re: Making a wifi bridge so risc os can work any where in ho
Posted: Mon Jan 18, 2016 3:49 am
by DavidS
Why not just use an extra Raspberry Pi B running a stripped down Linux system as the bridge? It seems much more cost effective to me.
Personally I just have Cat 5E cable strung to every room from my wired router (I do not use 802.11 [aka WiFi]), though have thought about using a bridge at locations other than home.
Posted: Mon Jan 18, 2016 4:30 am
by stylx
For me it was cheaper to buy a second hand notebook £20 then use another pi + wifi dongle and power supply that comes nearer the £30 mark and a full mains wifi bridge is £35 and above,
but I bett most pi users have at least one laptop/netbook in the house that they can use as a bridge and it will cost then nothink to set up and use .plus they can use both computer at the same time and there some great tutorial on line and they can edit this forum for example and look up general information to me it make perfect sense plus the network socket on the pi will never run that fast as it coupled through the usb it slow
Posted: Mon Jan 18, 2016 6:19 am
by fanoush
There are also those mini 4g routers https://wiki.openwrt.org/toh/unbranded/a5-v11 on ebay for ~ 8USD. For extra points you can also flash them with openwrt but it is not needed for this, it can do such wifi to ethernet routing out of box.
Posted: Mon Jan 18, 2016 6:26 am
by dfeugey
There are a lot of Wifi tu Ethernet bidges. For 3G/4G one simple solution is simply a 3G/4G key, as ComCentre supports them...
http://www.thomas-milius.privat.t-onlin ... /Computer/
Posted: Mon Jan 18, 2016 1:38 pm
by LeoWhite
I've successfully used a Vonets Mini300 ethernet to WiFi Bridge under RISC OS before. Its relatively cheap from ebay, small and is powered via USB.
I did set it up on a non-RISC OS machine first (To connect to my WiFi Access Point), although the latest version of NetSurf or Otter browser may be able to access the config page.
