scarrabri
RISCOS with pi 2
Tue Aug 18, 2015 5:55 am
Hi will Risc os work ok with the raspberry pi 2 as I have just ordered one and although I am new to this I really like the Risc operating system and have it working really well with raspberry pi1 even though I have much to learn but get immense fun out of it all. Brian.
ame
Re: RISCOS with pi 2
Tue Aug 18, 2015 5:59 am
GavinW
Tue Aug 18, 2015 12:46 pm
I have been using RISC OS on a Raspberry Pi 2 since February. Currently RISC OS 5.23.
In fact, as I happen to have a spare monitor, I have just bought another Raspberry Pi 2 so that I can I have a separate Linux machine without having to fiddle with micro-SDcards.
otium negare negotium vanum
scarrabri
Tue Aug 18, 2015 6:02 pm
GavinW wrote:I have been using RISC OS on a Raspberry Pi 2 since February. Currently RISC OS 5.23.
Well I am pleased and grateful for your reply, Brian
scarrabri
Tue Aug 18, 2015 6:40 pm
ame wrote:Allegedly the 2B is supported:
https://www.riscosopen.org/wiki/documen ... SD%20image
Thank you my friend very grateful to you .Brian
aidan_the_gasman
Mon Jan 04, 2016 8:28 am
Hi guys,
I run RISC OS Pi (I think it's version 5.21) on a Pi model B+. However, this SD card isn't recognised by my new RPi 2 model B (it only boots as far as the rainbow screen).
Is there a way to upgrade the RISC OS installation on the SD card so that I can use RISC OS on my RPi 2? Importantly, I need to keep it compatible with the model B+ too.
Cheers,
Aidan.
Burngate
Tue Jan 05, 2016 3:25 pm
Probably the easiest way is to copy everything off to a usb flash-drive / thumb-drive / other-name-for-the-same-thing, then put a brand new image on your SD card.
The latest image should work for all Pi's from the oldest original B to the latest 'n' greatest 2B (and the Zer0, though I can't vouch for that as I don't have one)
Then you can copy back the things you want.
Return to “RISCOS”
