Copy content of image to sd card instead of whole image
Posted: Thu Jun 07, 2012 6:55 am
by poseidon
I managed to mount the image file, thank you, AndrewS. But just copying the files to the partitions of my sd card will not work, I guess. There are numerous ELF- and BIN files, which have to be copied in a special way.
How do I proceed to install arch from the content of the image to a 6 gig sd card instead of dd'ing the whole image with its only 2 gigs?
Reagrds
poseidon
Re: Copy content of image to sd card instead of whole image
Posted: Thu Jun 07, 2012 7:54 am
by praest76
I'm sure it's possible but awkward, why not just dd the 2GB over and then resize the partition to fill the card? That's what I did. Is there a reason you aren't doing that which I've missed?
Posted: Thu Jun 07, 2012 8:53 am
by poseidon
Yes, very bad experience with SD cards. Most don't work properly, even recently bought ones. On my 16 gig Transcend it takes ages to resize a partition :-(. Formatting them works, however.
Regards
poseidon
Posted: Thu Jun 07, 2012 11:29 am
by angel6700
I posted a solution to this. chek if it's usefull fo you:
http://www.raspberrypi.org/phpBB3/viewt ... 617#p89617
regards.
Posted: Thu Jun 07, 2012 11:43 am
by grumpyoldgit
It only takes a couple of minutes to resize a partition with gparted.
Posted: Fri Jun 08, 2012 7:12 am
by poseidon
angel6700 wrote:Hello,
regards.
Man, you definitely made may day! Works like a charm!
Many thanks
poseidon
Posted: Fri Jun 08, 2012 8:01 am
by Joe Schmoe
regards.
That's interesting - it's basically the sort of thing that I have been recommending - that is, copying files out of the image to the card. Gives you more control over what you are doing.
I just have one question, though. What is "copy"? Did you mean "cp"?
Posted: Fri Jun 08, 2012 11:25 am
by angel6700
Sorry, it's my error. Of course i mean cp.
Thanks for notifying that. I can not edit my post..
