naicheben
Anyone getting MCEUSB Remote to work?
Mon Jun 04, 2012 8:24 pm
I'm trying to get a USB-Receiver
Bus 001 Device 004: ID 0471:0815 Philips eHome Infrared Transceiver
to work, but I might miss something.
All HowTos I found say there should be a device in /dev/input/by-id/ but there is only my keyboard.
Is there a special way to setup this remote receivers in Archlinux? I know the RPi can handle it, because OpenElec works like a charme with it.
What info can I provide?
lsmod:
[root@alarmpi pi]# lsmod
Module                  Size  Used by
rc_rc6_mce               884  0
ir_mce_kbd_decoder      3340  0
ir_sony_decoder         1500  0
ir_jvc_decoder          1588  0
ir_rc6_decoder          2108  0
ir_rc5_decoder          1508  0
ir_nec_decoder          2012  0
ir_lirc_codec           3092  0
lirc_dev                6796  1 ir_lirc_codec
rc_core                11656  8 ir_lirc_codec,ir_nec_decoder,ir_rc5_decoder,ir_rc6_decoder,ir_jvc_decoder,ir_sony_decoder,ir_mce_kbd_decoder,rc_rc6_mce
ipv6                  221660  12
snd_bcm2835            15316  2
snd_pcm                50640  2 snd_bcm2835
snd_page_alloc          2612  1 snd_pcm
snd_timer              14512  1 snd_pcm
snd                    28724  6 snd_timer,snd_pcm,snd_bcm2835
soundcore                440  1 snd
evdev                   6820  0
dmesg
usb 1-1.2: new full speed USB device number 4 using dwc_otg
usb 1-1.2: New USB device found, idVendor=0471, idProduct=0815
usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
usb 1-1.2: Product: eHome Infrared Transceiver
usb 1-1.2: Manufacturer: Philips
usb 1-1.2: SerialNumber: PH00EKwn
lirc_dev: IR Remote Control driver registered, major 251
IR LIRC bridge handler initialized
IR NEC protocol handler initialized
IR RC5(x) protocol handler initialized
IR RC6 protocol handler initialized
IR JVC protocol handler initialized
IR Sony protocol handler initialized
IR MCE Keyboard/mouse protocol handler initialized
naicheben
Re: Anyone getting MCEUSB Remote to work?
Thu Jun 07, 2012 7:47 am
Found out the module mceusb is a kernel module. I Thought it was from lirc. So now I recompile the git-kernel like in the wiki described here: http://elinux.org/RPi_Kernel_Compilation#Arch_Linux.
I had an error reporting directory tools was allready there at the point were you download the tools for imagetools-uncompressed.py . I had to cd out of the kernel dir to do so.
The wiki does not understate when it says 6h for compiling the kernel.... I had it running over night ...
Return to “Arch”
