Apache not running
Posted: Sat May 26, 2012 6:46 pm
by Warringer
I just got my Pi and put Arch on it to run my OwnCloud...
Apache was installed along with it and now Apache does not run. And yes, I have tried to run it manually and added 'httpd' to the rc.d.
Re: Apache not running
Posted: Sun May 27, 2012 5:46 pm
by pepedog
In httpd.conf check Listen line, and docs go in /srv/http
Good help here
https://wiki.archlinux.org/index.php/Apache
Posted: Sun May 27, 2012 10:48 pm
by Warringer
Not the first time I've set up Apache, first time on Arch through.
So I did check the usual suspects, like listen, hostname and the like.
Apache still won't start.
Oh well, I moved to Cherokee and now it works. :)
Posted: Mon Jun 04, 2012 6:19 pm
by Casalor
Warringer wrote:Not the first time I've set up Apache, first time on Arch through.
I'm a complete newb at apache but I found the help in this link worked ok for me. I'm all up and running with it without a problem.
https://wiki.archlinux.org/index.php/LAMP
