drirr
Re: Archlinuxarm v6 hard float
Tue Sep 18, 2012 8:07 pm
Nice, thanks for all the hard work (to everyone involved)! Will give it a go during the weekend when I have the time to fiddle around.
Raspberry Pi (rev 000f, 512MB RAM) with heatsinks and a modmypi case running Arch Linux ARM (armv6h) hooked up to a 750GB 2.5" USB-harddrive
mupi
Wed Sep 19, 2012 2:59 am
What does v6 refer to? ARM instruction set version, or ALARM version?
mupi
Wed Sep 19, 2012 5:15 am
Here are the results of the LINPACK benchmark on both the v5-nohf and v6-hf Arch versions. Both were done on a stock OS without any overclocking. I'm using arm240_start.elf.
v5-nohf
Enter array size (q to quit) [200]: 200
Memory required: 315K.
LINPACK benchmark, Double precision.
Machine precision: 15 digits.
Array size 200 X 200.
Average rolled and unrolled performance:
Reps Time(s) DGEFA DGESL OVERHEAD KFLOPS
4 0.68 88.24% 5.88% 5.88% 8583.333
8 1.36 88.24% 5.88% 5.88% 8583.333
16 2.72 88.24% 5.88% 5.88% 8583.333
32 5.43 89.69% 4.60% 5.71% 8583.333
64 10.87 91.44% 2.67% 5.89% 8591.724
v6-hf
16 0.55 90.91% 3.64% 5.45% 42256.410
32 1.11 89.19% 1.80% 9.01% 43511.551
64 2.22 86.49% 3.15% 10.36% 44167.504
128 4.43 87.81% 3.39% 8.80% 43511.551
256 8.86 88.15% 2.93% 8.92% 43565.469
512 17.71 87.58% 3.22% 9.20% 43728.027
angel6700
Wed Sep 19, 2012 6:08 pm
trying the new image... but... I think the username/password are no more the same as before.
Which user is defined or which is the root password?
Thank you.
Best regards, and thanks for the Hard work ;)
Edit: Forget this. I rebooted and then it worked as expected.
sdjf
Sun Sep 23, 2012 3:43 pm
The 23 Sep Hard Float version has been put on the downloads page, but i am concerned as it is significantly smaller than the other images that were like 193MB-208MB, being only like 159MB.
How come it is so much smaller?
FORUM TIP: To view someone's posting history, sign in, click on their user name, then on "Search User's Posts." || Running ArchLinuxArm on Model 2B and 512MB Model B
pepedog
Sun Sep 23, 2012 5:14 pm
Yes, smaller because I was shown the way of localepurge, you learn something new every day
sdjf
Sun Sep 23, 2012 6:48 pm
So, that means it is just cleaner but nothing was removed that will require more downloads by Pacman? I ask as my Pi will not have internet access for a while...when it finally comes.
pepedog
Sun Sep 23, 2012 8:57 pm
Nothing missing, function as before except rc.conf no more, now systemd, and very fast boot. I heard that all the boards made in South Wales have this run on them for testing
sdjf
Sun Sep 23, 2012 9:50 pm
Thank you very much. This is cool, less download time and faster. :o)
Return to “Arch”
