MHI
after pacman -Syu...
Wed Jul 18, 2012 7:09 pm
...mountig root read-only fails.
what i did wrong? I tried to shutdown -F to run fsck, but the error occurs as before.
any suggestions?
thanks, MHI
spennig
Re: after pacman -Syu...
Wed Jul 18, 2012 7:13 pm
Me too! Possibly related to the recent libsystemd update ??
Can be worked around by setting the sixth field (fs_passno) to 0 in /etc/fstab (so the system does not attempt to fsck /).
MHI
Wed Jul 18, 2012 7:36 pm
I tried that also, but in the other console i'm waiting for pacman generating master key... since more than 15 mins now! :-( Process seems to be up, ps told me +SL
...waiting...
Generating pacman keychain master key...
21:53CET now... process ...
...still sleeping...
elmurato
Wed Jul 18, 2012 7:55 pm
MHI wrote:I tried that also, but in the other console i'm waiting for pacman generating master key... since more than 15 mins now! :-( Process seems to be up, ps told me +SL
...waiting...
That might help ;)
https://wiki.archlinux.org/index.php/Pa ... entropy.3F
ph0ng
Thu Jul 19, 2012 9:16 am
Starting from an old image (2012-07-10) I upgraded package by package until the "Mounting root as read-only [FAILED]" message appeared. initscripts-2012.06.3-2.1-any is the package that breaks this step in the boot sequence (perhaps not very surprisingly). Unfortunately, initscripts-2012.06.3-2.1-any also fixes a major problem in systemd-186 which disallows all non-root logins.
I will report the issue to the archlinuxarm git tracker. In the mean time, perhaps we have to live with it. At least for me, it does not seem to create any problems.
ph0ng
Thu Jul 19, 2012 10:13 am
Update
See https://github.com/archlinuxarm/PKGBUILDs/issues/211 for more information. That solution works fine for me, but perhaps you might want to wait for an official patch.
MHI
Sat Jul 21, 2012 12:27 pm
Thanks a lot!
latki8
Wed Aug 01, 2012 3:15 pm
Today I used archlinuxarm for the first time followed the system update instructions but when I tried to update pacman it hung while trying to generate the keychain. I saw this post but when I checked out rc.sysinit, I found that the change had already been made, although it now also has
'run_hook sysinit_start' between the 'fi' and 'bootlogd'.
Is there some other reason why the key generation would hang?
ph0ng
Wed Aug 01, 2012 7:35 pm
These are two unrelated matters, and yes the above mentioned problem is solved in the latest version of initscripts.
I am pretty sure pacman didn't hang. Switch to another terminal and run some heavy I/O, read more about it here: https://wiki.archlinux.org/index.php/Pa ... he_keyring
Return to “Arch”
