How to use SVGAlib ?
Posted: Sun Jul 08, 2012 9:04 am
by Rasp333
I'm new users of Arch, and I know a bit linux system.
I would like to make graphics without using X server.
So I found I could use SVGAlib.
I tried that code snippet :
 #include <stdio.h>
 #include <stdlib.h>
 #include <vga.h>
 int main(void)
    vga_init();
    vga_setmode(1);
    vga_setcolor(14);
    vga_setmode(TEXT); //retourner au mode texte (important)
    return EXIT_SUCCESS;
using thise Makefile :
prog:	main.o
	gcc -o prog main.o -lvga
main.o:	main.c
	gcc -o main.o -c main.c -W -Wall -ansi -pedantic -I/usr/src/linux-3.1.10-11-ARCH/include/video/ -I/usr/src/linux-3.1.10-11-ARCH/arch/arm/include/ -I/usr/src/linux-3.1.10-11-ARCH/include/linux/
When I first compiled, path was not found, this is why I added pathes in gcc command.
but now, I'm stopped on this error and I don't know how to correct it :
[root@alarmpi code]# make
In file included from /usr/include/stdio.h:34:0,
                 from main.c:1:
/usr/src/linux-3.1.10-11-ARCH/include/linux/stddef.h:4:28: fatal error: linux/compiler.h: No such file or directory
compilation terminated.
make: *** [main.o] Error 1
Of course, linux/compiler exists here : /usr/src/linux-3.1.10-11-ARCH/include/linux/compiler.h
but gcc can't find it though I gave it the path.
Please, if any could give me a help.
Re: How to use SVGAlib ?
Posted: Sun Jul 08, 2012 10:55 am
by pepedog
Is the package linux-api-headers installed?
Posted: Mon Jul 09, 2012 7:36 am
by Rasp333
I had installed pacman -S linux-headers.
I have installed linux-api-headers too now, but I still have the same error :
                 from main.c:1:
As you can see, compiler.h is in the path I added to gcc (/usr/src/linux-3.1.10-11-ARCH/include/linux/) :
[root@alarmpi code]# find / -name compiler.h
