portets
Other DE's
Tue Jun 25, 2013 4:53 am
Using a very high overclock and an external drive, Gnome 3.2 is very usable on Raspbian. Is there a way to get Gnome 3 working on Pidora?
It appears to already be installed, but I get "Failed to load session gnome" and then:
gnome-session[999]: Warning: Unable to find required component 'gnome-panel'
even though gnome-panel is installed.
And why is it pre-installed wasting space for it to not work?
tedsluis
Re: Other DE's
Tue Jun 25, 2013 5:35 am
portets wrote:It appears to already be installed, but I get "Failed to load session gnome"
This is a known issue. Xfce is the default desktop in Pidora, not Gnome. But you could install Gnome using yum.
You shoud install a desktop switcher and select neither xfce of gnome:
# yum install switchdesk switchdesk-gui
# switchdesk xfce
or
# switchdesk gnome
More info here: http://www.raspberrypi.org/phpBB3/viewt ... 51&t=45586
--- If you cannot divide then you cannot multiply. ---
portets
Re: Other DE's
Tue Jun 25, 2013 5:49 am
None of that worked. But I was just able to switch my DM to GDM from LightDM using:
systemctl -f enable gdm.service
By default GDM is masked for some reason.
And apparently gnome-panel isn't installed and I can't install it because it's missing:
libgnome-desktop-3.so.2
as well as a few other packages. libgnome is already installed but it is version 2.32.1-5
portets
Re: Other DE's
Tue Jun 25, 2013 8:18 pm
I also see that when trying to install gnome-panel, it tries to take in a mixture of gnome 3.4 packages from Fedora 17, and 3.6 packages from Fedora 18. Is this currently the expected behavior?
Return to “Pidora / Fedora”
