retronath
Debian Wheezy minimal for rpi2
Tue Feb 10, 2015 8:30 am
Hello
I've created a Debian Wheezy minimal 7.8 armv7 for the Raspberry Pi 2.
Nothing fancy, just a debootstrapped install including openssh-server.
# uname -a
Linux raspberrypi 3.18.5-v7+ #748 SMP PREEMPT Wed Feb 4 21:33:52 GMT 2015 armv7l GNU/Linux
username:password:
root:raspberry
Fits onto a 1+GB SD card.
http://d3aoq9hazbhpfk.cloudfront.net/rp ... 201.img.gz
Varol Keskin
Re: Debian Wheezy minimal for rpi2
Fri Feb 13, 2015 7:17 pm
I can not login as root. Default root password is not valid. raspberry is not working as password for root.
linux34
Sat Feb 21, 2015 1:38 pm
Hi / Merhaba
its working fine, Thanks.
The password is OK ;)
User: root
Pass: raspberry
retronath
Sun Feb 22, 2015 8:25 pm
Hey Varol
I've re-tested the password, it definatly works.
I also tested with some small PHP and the /etc/shadow hash just to make sure:
$ cat passwd_test.php
if (password_verify ("raspberry", '$6$lGtm23nO$qAMQohK62x7sgZVNAiGpYIIm4e99FAMKGtIcimzjKni4eptwtEP/vrFJ0tgOZFqFrRaKPJzauQ0uwObO6FqKC.' )) print "match\n";
$ php passwd_test.php
match
I would recommend re writing the image file.
linux34
Wed Feb 25, 2015 10:31 pm
Hi retronath.
Thnks for this image.
But, can we change the boot logo?
I will se debian logo in boot or my special logo?
Can we change wit your method?
Thanks.
linux34
Fri Apr 10, 2015 8:24 pm
Hi, can you make Debian 8 jessie image.
Thanks.
CHARL13IS
Thu Jul 09, 2015 11:34 am
Thank you so much for this, it's just what I'm after! :D
Return to “Debian”
