piotr-e
3G modem Huawey E3131.
Tue Aug 28, 2012 11:02 am
What does install modem USB Huawey E3131 on Raspbian?
Raspberry Pi, model B, revision 2, 256MB RAM; Raspbian; Huawei E3131 modem (it works :-) ); EasyCap 4CH USB DVR (it works, but very slow)
I'm sorry for my English.
piotr-e
Re: 3G modem Huawey E3131.
Tue Aug 28, 2012 4:12 pm
I'm sorry for my English in first post.
I have got Huawey E3131 USB modem and I would like to use this modem with Raspberry Pi, but I can not find driver/module for Raspbian.
Is it possible to install the modem on the Raspberry Pi?
redhawk
Tue Aug 28, 2012 4:21 pm
I have a Huawei E160 I managed to get it working for serial port communication but the dial-up Internet part didn't work for some reason.
Maybe you will have better luck than me http://www.raspberrypi.org/phpBB3/viewt ... 6&p=146663
Richard S.
piotr-e
Tue Aug 28, 2012 6:48 pm
redhawk wrote:I have a Huawei E160 I managed to get it working for serial port communication but the dial-up Internet part didn't work for some reason.
Richard S.
I installed Option iCon 225 on PC Debian and I hope it is similar method such as:
1. I use usb_modeswitch from here: http://www.draisberghof.de/usb_modeswitch/
2. I use HSO driver from here: http://www.pharscape.org/icon225.html
...and I don't use pppd or other standard solutions.
Now I find usb_modeswitch for arm: http://www.draisberghof.de/usb_modeswit ... static.bz2
I try it...
piotr-e
Wed Sep 19, 2012 11:31 am
I can switch modem from CD to modem by using usb_modeswitch.
apt-get install usb-modeswitch
usb_modeswitch -v 12d1 -p 14fe -V 12d1 -P 1506 -M "55534243123456780000000000000011062000000100000000000000000000"
Then I need wvdial for Raspbian Wheezy armel. Where can I find it?
piotr-e
Wed Sep 19, 2012 9:09 pm
So, I need also option.ko driver and usbserial package.
Without wvdial, option.ko module and usbserial package my E3131 will does not work.
pygmy_giant
Wed Sep 19, 2012 9:20 pm
sakis3g works for my E220
Ostendo ignarus addo scientia.
piotr-e
Fri Sep 21, 2012 5:45 pm
pygmy_giant wrote:sakis3g works for my E220
I have Debian Wheezy Armel and I cannot install sakis3g. Where can I find sakis3g? I have got only http://debian.net/debian into my sources.list file.
Edit 19:50: E3131 work with CDMA networks, but sakis3g doesn't work with CDMA. :(
piotr-e
Sat Sep 22, 2012 6:30 am
AT commands works... :D
... but NetworkManager, Sakis3G, doesn't work for my E3131 with CDMA networks, WvDial not exist into repo. :(
So I need other script or program to manage the modem.
What can you suggest?
piotr-e
Sun Sep 23, 2012 5:39 am
I used command lsusb and I see:
Bus 001 Device 007: ID 12d1:1506 Huawei Technologies Co., Ltd. E398 LTE/UMTS/GSM Modem/Networkcard
...but I have E3131 modem.
Modems E3131 and E398 are different. E3131 have CDMA support, but E398 haven't CDMA support.
Maybe is it a driver problem :?: :?: :?: :?: :?:
piotr-e
Sun Sep 23, 2012 9:07 pm
My E3131 works :!: :!: :!: :!:
I run Sakis3g. :D
pygmy_giant
Sun Sep 23, 2012 9:11 pm
see
piotr-e
Mon Sep 24, 2012 4:53 am
pygmy_giant wrote:see
I had problem with running of Sakis3g and on www page of Sakis3g is info:
Important
Sakis3G only works with GSM networks. Connecting with a CDMA network is not yet possible.
...but I try and modem works. :D
Gawron
Mon Dec 03, 2012 11:30 pm
Hi there!
I have bought Raspberry Pi today and I would like to connect it to the Internet via 3G, but i am begginer.
I have E398, but probably i will buy E3131 anyway.
Can you tell me in ordinary language how to connect E3131 or E398?
I have only clear installation of Raspbian “wheezy” and its my first time with linux. I want to learn something new, but i dont really know how to start...
I tried with Sakis3G scripts, but i dont really know how set up the modem...
Do I need any other files?
Thanks for replies, and sorry for my low experience.
Raspberry Pi: Model B rev. 2
piotr-e
Thu Dec 06, 2012 8:22 pm
Gawron wrote:Hi there!
First you connect modem to USB and make two commands:
lsusb
dmesg
and results paste here.
PS.
English is my second language.
Gawron
Sat Dec 08, 2012 7:52 pm
Thanks for Your reply!
[ 134.604563] usb 1-1.2: New USB device found, idVendor=12d1, idProduct=14fe
[ 134.604596] usb 1-1.2: New USB device strings: Mfr=2, Product=1, SerialNumber=0
[ 134.604614] usb 1-1.2: Product: HUAWEI Mobile
[ 134.604626] usb 1-1.2: Manufacturer: HUAWEI
[ 134.623427] scsi1 : usb-storage 1-1.2:1.0
[ 134.624830] scsi2 : usb-storage 1-1.2:1.1
[ 135.624710] scsi 2:0:0:0: Direct-Access HUAWEI SD Storage 2.31 PQ: 0 ANSI: 2
[ 135.626162] scsi 1:0:0:0: CD-ROM HUAWEI Mass Storage 2.31 PQ: 0 ANSI: 2
Its only a part of the file.
I have uploaded txt file in the attachment.
PS. English is also my second language :)
Listing.rar
(5.39 KiB) Downloaded 364 times
piotr-e
Sun Dec 09, 2012 5:29 pm
Gawron wrote:Thanks for Your reply!
:D
Witam,
I zapraszam na polskie forum. Tutaj jest wszystko dokładnie opisane.
PS. Oczywiście zakładam, że nie jesteś studentem z wymiany...
Gawron
Sun Dec 09, 2012 8:21 pm
Hi!
Thanks for your reply!
I have just found this forum and installed
 sudo apt-get install ppp usb-modeswitch
Now its working fine!
Thanks!
cyanarnofsky
Tue Jul 01, 2014 11:41 pm
Curious how your guys speeds are. Mine through wvdial with PPP are really slow. I went through and checked all baud rates matched for a consistent flow but I get like 32-64KBps where 3g should be near 1MB/sec. Any ideas how to open that up?
Return to “Debian”
