sunone
getting stuck during download
Sat Jul 14, 2012 9:30 pm
Hi all
I am very happy with my new rapsberry.
However, I m encountering the following problem:
If I download something that will take more than 10 minutes or I am getting something with transmission (torrent) the system is very often freezing (completely stuck, I need to reboot).
I am using transmission from the package obtained via apt-get
Debian squeezy
The CPU bar is not completely full (therefore I don't think it is something related to that)
I have the suspect it is something related to the screensaver, I tried extending the screensaver time but it doesn't solve the problem. Moreover, it seems that the command
xset s off (to shutting down the screensaver)
doesn't work. If I write it in the xinitrc file than I have further problems: No mounting of usb stick possible.
The overall story is very strange, but it can be that the two problems are unrelated.
Thanks to everybody will help me in advance
sunone
Re: getting stuck during download
Sun Jul 15, 2012 9:59 am
Ok, I am definitely sure it is the screensaver, since I timed when the crush happens.... and it s exactly after 10 minutes (the default time for the screensaver).
I am writing from command line
xset s off ,
but it is not solving the problem. How do I destroy this annoying screensaver ?
stevepdp
Sun Jul 15, 2012 10:51 am
Do the following other options detailed here work for you?
sunone
Sun Jul 15, 2012 11:12 am
stevepdp wrote:Do the following other options detailed here work for you?
As I wrote in the first message I tried all the possible xset commands. No they don't work. If I put them in the xinitrc file, it works but then I cannot mount any usb memory storage (very very strange)
If I write it in the command line before lunching startx
I got the following error
"unable to open display """ " even I put sudo in front
LucaParoni
Re: getting stuck during screensaver
Sat Jul 21, 2012 7:41 pm
Hi everybody,
I just start to use my raspberry today and everthing is fine.
Im using the Debian SO ( I will pass to raspbian in the next days).
For the moment by the way I have this problem with the screensaver. At somepoints it started the screensaver and now I cannot do anything. No response from the keyboard and mouse.
What I have to do? Is it possibile to reboot the SO in someway avoiding the idea of take out the power charger of the raspberry? or is there a command to close the screensaver?
I just see what you see in the image attached.
I really dont know what to do.
thanks a lot,
Luca
screensaver runnging creating this shapes
Return to “Debian”
