Page 2 of 2
Re: Screen Overlay
Posted: Fri Apr 06, 2012 2:40 pm
by JLC333
First of all, I need to be able to buy my Raspberry
Re: Screen Overlay
Posted: Mon Apr 09, 2012 3:07 pm
by mahjongg
Perhaps you could use the Parallax propeller chip, (a microcontroller with eight CPU cores, and the ability to generate video signals) together with some fast opamps with three state outputs for the output mux, and a circuit to extract sync pulses from the life video input for syncing the output of the propeller video to the life video stream.
The propeller is probably able to synchronise the video it generates to the syncpulses it receives, and can control the three state inputs of the opamps to select which of the two signals to pass. It would probably also be possibe but very difficult to extract the colorburst signal, and synchronise the propeller video generation with it, but using monochrome color output (without the colorburst signal) should be doable. You can put your question here:
http://forums.parallax.com/for.....eller-Chip
Re: Screen Overlay
Posted: Tue Mar 29, 2016 1:36 pm
by clacktronics
Have you seen this Arduino solution?
http://nootropicdesign.com/ve/#library
It uses the lm1881 to extact the sync and makes the overlay, potentially you could do the same with the Pi but I am not sure if you could get the same kind timing precision. It is all worked out already so you could actually just send the information you want on screen over serial to an arduino.
Re: Screen Overlay
Posted: Wed Aug 15, 2018 8:37 am
by RaspIG007
I have a very similar requirement for a project i am working on,, did you end up implementing this design? If so, can you please advise on your chosen method.
