HizMama
ROS on Raspberry PI?
Fri Jan 25, 2013 7:27 pm
Hey guys,
i was wondering if it is possible to run ROS with or w/out ubuntu on Raspberry PI. Thanks in advance! :lol:
gritz
Re: ROS on Raspberry PI?
Fri Jan 25, 2013 9:41 pm
If you mean Robot Operating System then I think "Yeah, eventually, sort of..." is somewhere in the ballpark. :)
Some compilation instructions here: http://www.ros.org/wiki/groovy/Installa ... ian/Source
Whopping big thread about it all here: http://www.raspberrypi.org/phpBB3/viewt ... &start=100
HizMama
Fri Jan 25, 2013 10:27 pm
Thanks for the input! I had Raspbian until today but I changed it to Debian since all the code online for installing ROS is for Debian, however, if i type in something like "sudo apt-get install python-rosinstall python-rosdep" the terminal is unable to locate the packages rosinstall and rosdep.
HizMama
Fri Jan 25, 2013 10:35 pm
also, once i type in "sudo apt-get install build-essential python-yam1 cmake subverion wget python-setuptools mercurial git-core" the terminal reads "Unable to locate package python-yam1"
gritz
Fri Jan 25, 2013 11:00 pm
Hi HizMama, I should point out that I know very little about ROS, so I can't really be much help. Perhaps it would be an idea to PM a moderator and ask them to move this thread to the "Automation, sensing and robotics" part of this forum so that knowledgeable folks can weigh in.
Hope this helps. :)
Spid
Fri Jan 25, 2013 11:24 pm
Raspbian is Debian Whhezy 7 ARMv7 and compiled to work the PI ARMv6 architecture, it would be easier to install the latest 16-12-2012 Raspbian “wheezy” the latest version of Debian is seriously out-of-date and should not be used.
Anyway there is a mega-posting about ROS here: http://www.raspberrypi.org/phpBB3/viewt ... =37&t=6552
I will always assume you are running Raspbian for desktop and Raspbmc for XMBC !
Return to “Staffroom, classroom and projects”
