Page 13 of 13
Re: TinyTOSLINK (digital audio output) now for B+, too
Posted: Wed Sep 06, 2017 9:19 pm
by vylpi
first of all I would like to thank you all for the good work and sharing knowledge!
My new Pi Zero W should serve as a music player. From my first research I thought I just molder a Toslink transmitter to the correct pins and configure Raspian... Poor research! (Btw: Why doesn't that work???)
But reading this thread gives me hope for a solution. Is this TinyTOSLINK available for Pi Zero W? The "wired" solution (like in http://abload.de/img/rev_b_pluse7oi5.jpg) suits the purpose, the perfect PCB is not necessary.
BNC would be as good.
Thank you very much and best regards
vylpi
Posted: Thu Sep 07, 2017 3:46 pm
by BenjaminKe
Hi vylpi
Connecting a Toslink transmitter directly is not really possible, because you need a very accurate timing for the optical signal.
The Raspberry Pi has a Audio interface and you just need a sound processor which converts this to the optical signal.
If you buy my board it should fit onto the Pi Zero W like on a normal Pi B+ (because the header should be the same).
You just need to solder the header onto your Pi - if you want I can also include a header for you to solder.
Picture:
http://postimg.org/image/4vumaloa9/
Best Regards
Benjamin
Posted: Fri Sep 08, 2017 5:50 pm
by vylpi
Hi Benjamin,
yes, perfect, pm sent.
Kind regards
vylpi
Is there a way to disable tinytoslink via software?
Posted: Thu Sep 28, 2017 3:30 pm
by dieterhatn
I have a receiver that only has 1 digital input, so i connected my TV and tinytoslink with a Y-Splitter to the receiver.
The tinytoslink module emits light all the time, so I cannot hear the sound of my TV.
Is there a way to disable tinytoslink by software, so I can disable it when I want to watch TV and enable it again if i want to hear music?
Posted: Thu Sep 28, 2017 4:25 pm
by BenjaminKe
what OS do you use?
On OpenElec and LibreElec the transmitter shuts off when there is nothing to transmit.
I had a similiar issue, but didn't want tu use a Y cable or a simple switch with a remote.
So I also designed a optical audio switch (with automatic input detection, 4 or 7 inputs and some optional nice features).
You can take a look at it here:
https://www.tindie.com/products/Beni_Sk ... io-switch/
Maybe you are interested in something?
Best Regards
Benjamin
Posted: Thu Sep 28, 2017 4:29 pm
by dieterhatn
BenjaminKe wrote: Maybe you are interested in something?
Best Regards
Benjamin
That looks awesome, but I guess that's a little too much for just two inputs.
The TV does not emit light when it is in standby.
I'm running osmc on my raspberry pi. I'm using shairport-sync to listen to music.
When I restart the Pi, the transmitter shuts off when there is no audio input just fine. But if I leave it running for a few days, something causes it to emit light.
I stopped the shairport-sync service, but that did not stop it from emitting light.
Edit:
You should have told me about that a few weeks ago, I just bought some sabre dac.
If I still were in need of a dac, i would definately buy your board.
Posted: Thu Sep 28, 2017 4:59 pm
by BenjaminKe
the cheapest version has 4 inputs and 2 inputs wouldn't be cheaper - and maybe you have a 3rd device sometime in the future ;)
with the prioritized inputs on this switch it would definetely work for you
if we make a private order I can make a special price for you (Tindie charges fees)
maybe you should try LibreElec - maybe this works better for you?
I'm only using LibreElec and the transmitter always switches off.
Best Regards
Benjamin
Posted: Thu Sep 28, 2017 5:01 pm
by dieterhatn
I see If I can sell my DAC, if someone buys it I will get right back to you.
Maybe shipping can get a little cheaper as well, since we're neighbours (Hallo aus Deutschland :D )
Posted: Thu Sep 28, 2017 5:04 pm
by BenjaminKe
Yes sure just write me a PM :)
Posted: Sun Oct 01, 2017 6:06 pm
by vylpi
So finally my Pi Zero W is a neat little Music Player:
Software:
- Raspbian
- MPD controlled via MPDroid on old Android Phone
- YMPD (just for testing)
- Music on a network share
Hardware:
- Pi ZeroW
- TinyTOSLINK PCB
- Oak wood
- High End optical cable, Camtech DAC, etc.
Thank you very much, Benjamin!
Posted: Wed Nov 01, 2017 7:36 am
by vylpi
Hi all,
does anyone experience "clicks" while starting / stopping playback? I do: When I start playback, it seems my DAC wakes up and needs to tell me it found some input.
Is there way to let the optical output stay active to keep it in sync with the DAC? I think of some silence track in a loop or such.
Thanks for any comment!
vylpi
Posted: Wed Nov 01, 2017 4:19 pm
by BenjaminKe
Hi vylpi,
depending on the software which you use for playback on the Pi there should be a "keep alive" option somewhere.
Best Regards
Benjamin
Posted: Fri Jun 15, 2018 9:11 pm
by alaind
Hi Benjamin,
thanks for good work.
I am very interested on a TinyTOSLINK for my Raspberry Pi 3.
Are they still available?
Best Regards
Alain
Posted: Sat Jun 16, 2018 8:24 am
by BenjaminKe
Hi
yes they are still available.
Unfortunately the forum here turned off private messaging.
you can order it here:
https://www.tindie.com/products/Beni_Sk ... cal-audio/
Best Regards
Benjamin
Posted: Mon Oct 08, 2018 12:29 pm
by LEMAX
Hi Jörg,
Are you still able to supply this board? My requirement is as following:
For: Rpi3 B+
Board requirement: I need the board to have an input not an output through a Optical Digital Audio connector.
I basically need your board to receive the audio through the ODA input and I want to be able to use my rpi3 B+ to stream this audio signal through wifi.
I would be needing 2 boards for now.
Regards,
Michael
Posted: Mon Oct 08, 2018 4:08 pm
by BenjaminKe
Hi Michael,
I can provide this - I already replied on your message on Tindie.
Best Regards
Benjamin
Posted: Thu Nov 22, 2018 6:12 pm
by Yabadi
Hi
It looks amazing
How could i get one ?
Posted: Fri Nov 23, 2018 5:17 pm
by BenjaminKe
Hi
Best Regards
Benjamin
