Page 10 of 13
Re: TinyTOSLINK (digital audio output) now for B+, too
Posted: Fri Jul 01, 2016 8:22 am
by Eisdieler
Hey Benjamin,
As many before I'd love to get one of your Toslink Sets, the project sounds great. Shipping would be to Germany.
Hope to hear from you.
Best wishes and have a nice week-end,
fabian
Posted: Sun Jul 03, 2016 10:15 am
by Crockernr
Hi Ben
I am also interested in getting a couple of these. Do you do then for raspberry pi 3
And how much to send to new Zealand ?
Posted: Mon Jul 11, 2016 11:20 am
by nasty007
Hey Benjamin
im really interested for TinyToslink for PI2.
How much will shipping cost be to Croatia.
If you don't have any left, i would like to build one for myself, im skilled in that area.
Best regards
Posted: Wed Jul 20, 2016 10:18 am
by BenjaminKe
Hi all,
sorry for the late reply (seems like my email notification isn't workind anymore).
You all got a PM now.
To give some more details also here about prices and how to order:
fully assembled board: 20€
parts as DIY kit: 15€
PCB or parts only are available on request - just tell me what you want :)
Shipping:
Austria: 3€
Europe: 5€
Worldwide: 8€
Just write me a PM or post here and I will come back to you.
Best Regards
Benjamin
Posted: Fri Aug 05, 2016 1:32 am
by Bedgear
Has anyone tried one of these on the Pi Zero? I assume it wouldnt be an issue, but i havent seen anything about it in this thread.
Posted: Fri Aug 05, 2016 2:31 pm
by BenjaminKe
I didn't try it yet, but the 40 pin header should be the same so it should be no problem.
Best Regards
Benjamin
Posted: Thu Aug 18, 2016 5:29 am
by Crockernr
Anyone know any info on setting this up on RPi3 and openelec ?
Posted: Thu Aug 18, 2016 7:26 am
by BenjaminKe
You just need to add 1 line to the config.txt:
dtoverlay=hifiberry-digi
Then you can select the device in the Kodi settings.
Posted: Mon Aug 29, 2016 11:27 pm
by Manew
Hi BenjaminKe,
me as well is interested to buy an already assembled TinyTOSLINK board. It should be shipped to Germany.
Best regards,
Dirk
PS: As I'm new to the board I'm not yet able to write a PM to you.
Posted: Tue Aug 30, 2016 8:08 am
by BenjaminKe
Hi Dirk!
You got a PM :)
Posted: Tue Sep 06, 2016 7:46 am
by BenjaminKe
RPi3 Update
Finally I also got a RPi3 and the newest version of OpenElec supports the RPi3!
So I can confirm: the board also works on the Pi3 and Kodi is running really fast :)
Also LibreElec works just perfect!
The only problem with RPi3 and the currently newest OpenElec revision (6.0.3) is that it does not yet contain the newest kernel and there is a bug with the bluetooth driver which prevents the hifiberry driver from working correctly (the board will output only noise).
As most people won't need bluetooth the problem can be fixed by deactivating it:
Simply add 1 more line to the config.txt (just before the "dtoverlay=hifiberry-digi"):
dtoverlay=pi3-disable-bt
The overlay "pi3-disable-bt" is not included in OpenElec so you need to download it and copy it into the "overlays" folder on the boot partition of the SD card.
I have uploaded the file here:
http://www.share-online.biz/dl/SG38O2DORAM
On the latest LibreElec version (7.0.2) this bug is already fixed and everything is working perfect!
Best Regards
Benjamin
Posted: Tue Sep 06, 2016 8:01 am
by foresto
Benjamin, is the bluetooth bug present in the current LibreELEC release as well?
In case you're not aware, LibreELEC is a recent fork of OpenELEC, and nearly all the developers seem to have moved to it.
Posted: Tue Sep 06, 2016 9:48 am
by BenjaminKe
I can't say for sure - need to try it out
I'm still stuck to OpenElec because it works so perfect that I don't want to update :)
Posted: Wed Sep 07, 2016 7:52 am
by BenjaminKe
Just tried LibreElec:
The current LibreElec version (7.0.2) already has a newer Kernel and the HifiBerry Bluetooth bug on the Pi3 is fixed here!
Posted: Wed Sep 07, 2016 3:27 pm
by Midask
Midask wrote:
perryferryjny wrote:Hi All,
Did anyone try to use BenjaminKe's or [IDC]Dragon's board on Raspberry Pi 2 B with Raspbian Jessie? I'm having trouble with getting it to work. I don't want to use OpenELEC nor any other distro - I prefer to make it working on clean Raspbian.
I added HiFi Berry to device tree and disabled default audio card in /boot/config.txt:
#dtparam=audio=on
I see HiFi Berry in aplay:
pi@raspberrypi:~ $ aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: sndrpihifiberry [snd_rpi_hifiberry_digi], device 0: HifiBerry Digi HiFi wm8804-spdif-0 []
Subdevices: 1/1
Subdevice #0: subdevice #0
When I play flac file with mplayer over hdmi it is ok. But when I disable on-board sound and load HiFi Berry mplayer plays file but my AMP does not see digital signal on input. I don't have oscilloscope at home to check if anything is transmitted. But anyway I think it migth be raspbian configuration issue. dmesg show this output:
[ 4.839301] systemd-udevd[108]: starting version 215
[ 5.350307] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 5.558976] snd-hifiberry-digi sound: ASoC: CPU DAI (null) not registered
[ 5.559058] snd-hifiberry-digi sound: snd_soc_register_card() failed: -517
[ 5.692065] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 6.195203] bcm2835-rng 3f104000.rng: hwrng registered
[ 6.195658] snd-hifiberry-digi sound: ASoC: CPU DAI (null) not registered
[ 6.195689] snd-hifiberry-digi sound: snd_soc_register_card() failed: -517
[ 6.199150] snd-hifiberry-digi sound: ASoC: CODEC DAI wm8804-spdif not registered
[ 6.199190] snd-hifiberry-digi sound: snd_soc_register_card() failed: -517
[ 6.203286] bcm2708_i2c 3f804000.i2c: BSC1 Controller at 0x3f804000 (irq 79) (baudrate 100000)
[ 6.203657] snd-hifiberry-digi sound: ASoC: CODEC DAI wm8804-spdif not registered
[ 6.203690] snd-hifiberry-digi sound: snd_soc_register_card() failed: -517
[ 6.433326] wm8804 1-003b: revision E
[ 6.440736] snd-hifiberry-digi sound: wm8804-spdif <-> 3f203000.i2s mapping ok
I'm not sure if there are issues here. Does last line mean that wm8804 is operational?
Anyone have an idea how to debug it further?
Hi ! I've just received the device and I have the same issue. The device is working on OpenELEC but not on Raspbian, same problem !
Hi everyone ! It's been a while but now, everything is working, I had to choose AIF in alsamixer to have sound on Raspbian
Let me know if it's OK for you perryferryjny
Posted: Mon Sep 19, 2016 7:07 pm
by TJH
I'd love to order a TinyTOS from you for my new Pi 3 please..........
Posted: Mon Sep 19, 2016 9:17 pm
by BenjaminKe
You got a PM :)
Posted: Sun Sep 25, 2016 11:21 am
by Spank
Hi Benjamin,
I would like to order a board for my Pi3. Please let me know how to proceed.
Posted: Thu Sep 29, 2016 7:40 pm
by BenjaminKe
You got a PM :)
Posted: Tue Oct 11, 2016 1:00 pm
by xelon
Just to get this straight: I buy myself a RPi 3, your little wonderadapter, put them together and have an optical output? Thats amazing! :shock: Can I have one? (Germany)
Posted: Wed Oct 12, 2016 2:30 pm
by BenjaminKe
You got a PM :)
Posted: Wed Oct 26, 2016 10:33 pm
by zgtc
Hi there,
New in the forum so please let me first thank Jörg, Benjamin and the rest for all the hard work with these cards. I have a Pi2 + IQaudIO DAC+, wonderful combo i use with Volumio and NAS.
I would also like to get digital sound from my laptop and/or TV go through the DAC+, but it lacks toslink input. Quite sure I'd be able to get the proper combination of interfaces buying stuff at audiophonics or similar, maybe having to buy another DAC, but searching google I got here. Two questions:
1. Do you still have cards left? I live in Barcelona... :D
2. Would it (even theoretically) be possible to have a toslink input to the Pi2, and through a rotary encoder send a signal to alsa to change to audio source from the USB/NAS to use the audio coming from the toslink? This way I would use the current setup for volumio, but by selecting a different hardware source send digital sound to the DAC+ as well.
Thank you so much
Posted: Thu Oct 27, 2016 8:26 am
by BenjaminKe
Hi!
So you only need a Toslink input and no output is this correct?
Or do you want to have both?
Theoretically you could solder a Toslink Input instead of an output and do a little modification and you have a input hardware instead of an output.
Or you could also solder a wire with an extra Toslink input and you get an input AND an output at the same time (but with this way your second input connector is extra and not directly fixed on the board.
The hardware itself (the soundcard ID) has an input and an output channel.
But there is one thing I don't know: I have no idea how far the HifiBerry drivers (software) support a optical input (the have it available on the official PCB, but it is not assembled - so I guess the can support it somehow but you need to try around with this on your own.
And yes I still have board left :)
Best Regards
Benjamin
Posted: Thu Oct 27, 2016 12:12 pm
by zgtc
Hi Benjamin,
Yes, I only need Toslink INput. My approach is to try to send that audio to the DAC+ (which is connected to the Pi GPIOs) by switching a rotary encoder (and this changes the alsa settings, pressumably). This way I would not need extra cards nor a new DAC.
How do you see it? Would I need your card for this (and modify it for input) or should I simply get a toslink base and soldier that to some different pins in the Pi (would that need a controller)?
Thank you again!
Posted: Fri Oct 28, 2016 1:19 pm
by BenjaminKe
You got a PM ;)
