BenjaminKe
Re: TinyTOSLINK (digital audio output) now for B+, too
Wed Apr 06, 2016 8:39 am
yes it is possible to use both, because the output of the sound IC is connected to the optical output and the "normal" digital output.
I will write you a PM.
Best Regards
Benjamin
gsi095
Thu Apr 21, 2016 4:44 am
Have any left? what would be the price to Australia?
Dave
MATIpl
Sat Apr 23, 2016 11:26 pm
Hello
Sory for my english, I like to buy your tinytoslink. Can you sell it and send to germany or poland? What will be the price? Or can you send me how to make this board and what elements I need.
dab654
Sun Apr 24, 2016 4:48 pm
Hello!
I like it, will send you a PM next!
SavageThor
Sun Apr 24, 2016 11:33 pm
Might be late to the party but I got to try to get one. Do you have any left?
BenjaminKe
Mon Apr 25, 2016 10:58 am
Hi All,
yes I still have some left.
I will write you all a PM.
Best Regards
Benjamin
Midask
Tue Apr 26, 2016 11:00 pm
Hi Benjamin,
I was browsing the Internet in order to find a way to get TOSLINK on the RPI2 and I've found your topic. Can you tell me more about this device by PM (Shipping Price, Price, is it available for Pi2). I live in France.
Thanks a lot for your awesome work !
BenjaminKe
Wed Apr 27, 2016 7:27 am
Hi Midask,
yes it is for the RPi2 but should also work for others which have the same layout/pinout (B+, RPi3).
For the RPi3 you need a different (smaller) optical connector, because of the WLAN antenna which is mounted there.
I will send you a PM.
Best Regards
Benjamin
perryferryjny
Mon May 02, 2016 4:33 pm
Hi All,
Did anyone try to use BenjaminKe's or [IDC]Dragon's board on Raspberry Pi 2 B with Raspbian Jessie? I'm having trouble with getting it to work. I don't want to use OpenELEC nor any other distro - I prefer to make it working on clean Raspbian.
I added HiFi Berry to device tree and disabled default audio card in /boot/config.txt:
#dtparam=audio=on
dtoverlay=hifiberry-digi
I see HiFi Berry in aplay:
pi@raspberrypi:~ $ aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: sndrpihifiberry [snd_rpi_hifiberry_digi], device 0: HifiBerry Digi HiFi wm8804-spdif-0 []
Subdevices: 1/1
Subdevice #0: subdevice #0
When I play flac file with mplayer over hdmi it is ok. But when I disable on-board sound and load HiFi Berry mplayer plays file but my AMP does not see digital signal on input. I don't have oscilloscope at home to check if anything is transmitted. But anyway I think it migth be raspbian configuration issue. dmesg show this output:
[ 4.839301] systemd-udevd[108]: starting version 215
[ 5.350307] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 5.558976] snd-hifiberry-digi sound: ASoC: CPU DAI (null) not registered
[ 5.559058] snd-hifiberry-digi sound: snd_soc_register_card() failed: -517
[ 5.692065] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 6.195203] bcm2835-rng 3f104000.rng: hwrng registered
[ 6.195658] snd-hifiberry-digi sound: ASoC: CPU DAI (null) not registered
[ 6.195689] snd-hifiberry-digi sound: snd_soc_register_card() failed: -517
[ 6.199150] snd-hifiberry-digi sound: ASoC: CODEC DAI wm8804-spdif not registered
[ 6.199190] snd-hifiberry-digi sound: snd_soc_register_card() failed: -517
[ 6.203286] bcm2708_i2c 3f804000.i2c: BSC1 Controller at 0x3f804000 (irq 79) (baudrate 100000)
[ 6.203657] snd-hifiberry-digi sound: ASoC: CODEC DAI wm8804-spdif not registered
[ 6.203690] snd-hifiberry-digi sound: snd_soc_register_card() failed: -517
[ 6.433326] wm8804 1-003b: revision E
[ 6.440736] snd-hifiberry-digi sound: wm8804-spdif <-> 3f203000.i2s mapping ok
I'm not sure if there are issues here. Does last line mean that wm8804 is operational?
Anyone have an idea how to debug it further?
paradiza
Fri May 06, 2016 7:14 pm
Hi Benjamin,
I'm wondering, do you still have some parts left? Unfortunately I also came across this thread just now. I highly appreciate your efforts. Kudos to Jörg and all the others involved!
Cheers
zydawn
Sat May 07, 2016 1:54 pm
hi jorg are you still selling these toslink hats
just purchased a pi 3
paradiza
Sun May 08, 2016 11:40 am
Hi Jörg,
[IDC]Dragon wrote: So far I've published boards and schematics of all my creations, but with TinyTOSLINK I was hesitant, since there is Hifiberry Digi.
Now that the hardware design is kind of public, I'm reconsidering.
Just curious, what's the status of your reconsiderations? While the alternative designs of Benjamin et al are very nice in their own right, your concept still seems to be the most elegant solution so far. Thus I wonder whether you might eventually publish the details? I read your opinion on DIY-etching but some of us might have access to suitable facilities to get it done right. I'd love to give it a shot.
Thanks in advance!
dalter
Mon May 09, 2016 7:55 am
Hi BenjaminKe
Thanks for your awesome work. I have been looking for nice digital audio output for a long time.
If you have any left I would like to buy one.
Pls sent me pm or contact me via e-mail: zadarr@gmail.com
BR
dalter
BenjaminKe
Mon May 09, 2016 9:33 am
Hi Dalter,
yes I still have some left - I wrote you an email.
Best Regards
Benjamin
dmorts
Thu May 12, 2016 2:46 pm
I'm really interested in a TOSLink input. Would this be possible to produce?
gsi095
Thu May 12, 2016 11:57 pm
Hi Benjamin,
I received the board today, that's quick to Australia.
I got to wondering if it would also take an optical input from another device and then out to speakers using a USB DAC?
the board is really quite a quality piece of equipment.
Dave
BenjaminKe
Fri May 13, 2016 7:41 am
dmorts:
I wrote you a PM.
Dave:
The WM8804 chip has an input and and output.
So theoretically it is possible to use it also as input and capture a optical signal (there is a not assembled pinhead connector with 2 pins on the PCB - with a 0 ohm resistor you can connect one of these 2 pins to the input and connect your optical receiver here).
But I don't know if there is some support from the HifiBerry software for something.
Best Regards
Benjamin
Sandor
Sun May 15, 2016 6:37 am
Hi Benjamin, if at all possible I'd love to take one or two of these off your hands as well :) Board+parts would be fine, I don't mind soldering a little from time to time. Thanks!
EDIT: And a big thank you to Jörg too of course :)
BenjaminKe
Tue May 17, 2016 9:33 am
Hi Sandor,
sure :) - you got a PM.
Best Regards
Benjamin
Midask
Sat May 28, 2016 12:12 pm
perryferryjny wrote:Hi All,
#dtparam=audio=on
Subdevices: 1/1
Hi ! I've just received the device and I have the same issue. The device is working on OpenELEC but not on Raspbian, same problem !
NikkAlek
Wed Jun 15, 2016 2:02 am
Hi Ben,
I'd love to pick one of these up for my Pi3. What would be the cost with shipping to get one to me in Pennsylvania, USA?
aTTilaz
Tue Jun 21, 2016 10:06 pm
Hi Ben,
I would also love one of these, possible to get one posted to Australia?
antorsae
Fri Jun 24, 2016 5:36 pm
Hi Ben,
Im interested in your board to be used as a TOSLINK input. According to this: https://support.hifiberry.com/hc/en-us/ ... ital-input it may work.
Can you PM me if you have boards left?
Thanks!
maroi
Tue Jun 28, 2016 3:08 pm
Hi Ben,
i'm also interested in a board for the rasperry Pi 3.
Could you please make me an offer with shipping to austria?
regards
Skicraft
Thu Jun 30, 2016 11:08 am
Hi Ben,
I am also interested in creating a TOSLINK input for my Pi 3, do you have any left ?
