crazyx13th
Re: TinyTOSLINK (digital audio output) now for B+, too
Sun Aug 02, 2015 7:05 am
HeyJörg,
I would like to have one board. PM will be sent.
Thanks!
Cya CrazyX13th
montnemery
Sun Aug 02, 2015 7:19 pm
Here's some instructions for enabling use of the TinyTOSLINK in OSMC 2015.06-1:
  • Install OSMC and make sure it is working
  • Modify config.txt:
    • Add this line:
      dtoverlay=hifiberry-digi-overlay
    • Remove or comment out this line:
      dtoverlay=lirc-rpi
      Note: If not done, the system will freeze when playing audio through the TinyTOSLINK.
  • Reboot the RaspberryPi
  • In Kodi, go to Settings->System->Audio Output and change to ALSA
PS:
As mentioned elsewhere, the product is really neat and looks very professional.
Jörg was really nice to deal with, and the shipping was very quick.
A big thanks!
JonathanNet
Mon Aug 03, 2015 11:46 am
I got the TinyToslink to work with Openelec 5.0.8 with editing the config.txt in windows on the SD card
I just inserted the line: dtoverlay=hifiberry-digi
But then I installed the Openelec "OpenELEC-RPi2.arm-5.95.3.img" on a SD card it give me this error then I typed "dmesg"
[    6.033368] snd-hifiberry-digi sound: ASoC: CPU DAI (null) not registered
[    6.033415] snd-hifiberry-digi sound: snd_soc_register_card() failed: -517
[    6.051942] snd-hifiberry-digi sound: ASoC: CODEC DAI wm8804-spdif not registered
[    6.051996] snd-hifiberry-digi sound: snd_soc_register_card() failed: -517
[    6.256451] usb 1-1.2: reset high-speed USB device number 4 using dwc_otg
[    6.365902] ieee80211 phy0: rt2x00_set_rt: Info - RT chipset 5390, rev 0502 detected
[    6.406060] ieee80211 phy0: rt2x00_set_rf: Info - RF chipset 5370 detected
[    6.406897] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[    6.409281] usbcore: registered new interface driver rt2800usb
[    6.411106] snd-hifiberry-digi sound: ASoC: CODEC DAI wm8804-spdif not registered
[    6.411137] snd-hifiberry-digi sound: snd_soc_register_card() failed: -517
And it will not find the TinyToslink in the settings, any one that have a fix for that ? :)
BMS Doug
Mon Aug 03, 2015 12:15 pm
I expect OpenElec isn't using the same set of device tree rules yet, try following the advice for installing a HiFiBerry-Digi with OpenElec.
Doug.
crazyx13th
Thu Aug 06, 2015 9:30 am
Cool!
I got the TinyTOSLINK today and it's workin!
I habe a RPI B+ and OpenElec 5.0.8.
My way:
- enable ssh
- can't write to dir and files I remount the /flash dir-> mount -o remount,rw /flash
- I control /flash/overlays/hifiberry-digi-overlay.dtb was inside
- I added dtoverlay=hifiberry-digi-overlay at /flash/config.txt
- at Kodi/XMBC I reset the audio-settings, than choose ALSA as Audio-Output, Passthrough, AC3 and DTS ready
Between the most steps I reboot ;)
Cya crazyx13th
TomR
Thu Aug 13, 2015 11:01 am
Pm on the way
lilijo
Wed Aug 19, 2015 3:34 pm
Hey Jorg,
Can I too, request one of these? Please.
I m using new rapsberry pi 2 B with openelec,
Thanks for your hard work,
regards,
Lio
JacoE
Sun Aug 23, 2015 3:20 pm
Great work man, PM on its way!
I really appreciate the work that went into this. The other boards out there just did not catch my attention as much as this one.
waffel
Mon Aug 24, 2015 6:55 am
Hi Jörg,
Looking very very good.
Hope you can make me one.
Will send you a PM very soon...
oo7
Fri Aug 28, 2015 5:44 am
Hi Jörg,
this is exactly, what I was looking for! Great work!
Kind regards,
Tobias
adityaxavier
Sun Aug 30, 2015 5:17 pm
Hi Jörg,
Hope you are still doing this.. Need one shipped to india.
Please let me know the feasibility.
Thanks,
Aditya Xavier.
JonathanNet
Tue Sep 01, 2015 10:23 am
Any one here also have sound lag some times, like this thread I made on OSMC forum ?:
https://discourse.osmc.tv/t/sound-lags- ... times/7407
unerreichbar
Wed Sep 02, 2015 12:51 pm
It looks like what I'm looking for ...
foresto
Fri Sep 04, 2015 9:07 am
JonathanNet wrote:I got the TinyToslink to work with Openelec 5.0.8 with editing the config.txt in windows on the SD card
OpenELEC 5.95.3 broke it, but 5.95.4 fixed it. Try again with the new version.
foresto
Fri Sep 04, 2015 5:21 pm
Is anyone else seeing occasional jerkiness / uneven motion when using the TinyTOSLINK with Kodi? It happens to me on OpenELEC with Adjust Display Refresh Rate enabled, and Sync Playback to Display disabled. It doesn't seem to happen when I use HDMI audio output instead of the TinyTOSLINK.
seb1
Thu Sep 10, 2015 8:01 pm
Hi Jörg,
This is a very interesting project.
Hope it is still possible to order one.
Will send you a PM.
Regards
Seb
user879
Fri Sep 11, 2015 3:57 pm
Jörg,
Are these still available? This board you created is awesome!
Success is going from failure to failure without loss of enthusiasm - Winston Churchill
[IDC]Dragon
Sun Sep 13, 2015 8:08 pm
Yes, they are still available, but not for very much longer. The bottom of the box is visible.
Jörg
HungryShopper
Mon Sep 14, 2015 8:55 pm
Exactly what I have been looking for!
Will send a PM in the hope that the box is not yet completely empty...
shepneb
Sat Sep 19, 2015 5:04 pm
Hi, I think this is ideal as it looks like it will fit in my new flirc raspberry pi 2 case. Will PM in hope that there are some left. Thanks
SaiKo
Wed Sep 23, 2015 12:23 am
I had seen you offered the TinyTOSLINK before, but just now saw you also make one for the rpi2.
Are there any left?
May i pm you?
maxonline
Sun Sep 27, 2015 10:42 am
I like it, I'll send you a PM next. :)
[IDC]Dragon
Sun Sep 27, 2015 8:12 pm
A user in the german uC forum has successfully made a digital recording with TinyTOSLINK. It just works out of the box, he found out. Just connect an S/PDIF signal to the input preparation of my PCB. If you want an optical receiver instead, you may add it externally, and better remove the 75 Ohm termination resistor R4 when feeding its full swing logic signal.
Jörg
JacoE
Sun Sep 27, 2015 9:50 pm
I finally got my TinyTOSLINK after a long wait and I must admit its working flawlessly!
After updating OpenElec to 5.95.5, editing the config file and adding that code, it wasn't 2 mins and it was working like a treat, 5.1 sound output and all.
One happy person. :D
