LeSanglier
2268 PRAM Usb Key
Thu Sep 11, 2014 6:28 pm
Hi
I have a 16 Go Emtec 16 Go.
Raspbian can not recognize this usb key.
pi@station67 ~ $ dmesg
[ 2294.959981] usb 1-1.2: new high-speed USB device number 9 using dwc_otg
[ 2295.061103] usb 1-1.2: New USB device found, idVendor=13fe, idProduct=3e00
[ 2295.061139] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2295.061155] usb 1-1.2: Product: 2268 PRAM
[ 2295.061170] usb 1-1.2: Manufacturer:
[ 2295.068634] usb-storage 1-1.2:1.0: USB Mass Storage device detected
[ 2295.079958] scsi3 : usb-storage 1-1.2:1.0
[ 2296.081326] scsi 3:0:0:0: Direct-Access 2268 PRAM 1.00 PQ: 0 ANSI: 0 CCS
[ 2296.084143] sd 3:0:0:0: Attached scsi generic sg0 type 0
[ 2296.086363] sd 3:0:0:0: [sda] Attached SCSI removable disk
Do you have a tip to mount the key ?
Thx.
Mon blog sur le Raspberry Pi : http://framboisepi.fr/
Pour avoir plus de chance d'avoir une réponse à votre question,
allez sur le forum français Rasberry Pi : http://forum.raspfr.org
Re: 2268 PRAM Usb Key
Thu Sep 11, 2014 7:12 pm
This is just a guess... as the driver only shows sda, I suspect it could be unpartitioned storage. This is where the whole device (/dev/sda) is used instead of a partition (/dev/sda1). This is sometimes known a "floppy" mode, as floppy disks didn't have partitions.
Try "sudo mount -t vfat /dev/sda /media" (again I'm guessing that it could be a FAT type filesystem).
LeSanglier
Thu Sep 11, 2014 7:25 pm
rpdom wrote: Try "sudo mount -t vfat /dev/sda /media" (again I'm guessing that it could be a FAT type filesystem).
I have this error :
pi@station67 ~ $ sudo mount -t vfat /dev/sda /media/disk1/
mount: no medium found on /dev/sda
It is very strange... O_o
