il_diavolo
Motor controller defunct?
Fri Jan 24, 2014 3:57 pm
Before I start, yes, I do have the jumper on J7 installed.
I set up a small motor connected to the terminal block, together with an external 3v power supply, all as described in the manual. (The motor works when connected directly to the batteries.)
When I run either "motor" or "potmotor" (in C or Python), neither activates the motor. After another look at the manual I tried connecting 3.3v and ground (from Gertboard pins) directly to the pins Mot A and Mot B in J5. Table 3 in the manual indicates that this should produce a rotating motor. My multimeter stubbornly reads 0v between the Mot A and Mot B output terminals whatever I try.
Connecting my motor/battery setup to the open collectors, running "ocol", everything works properly.
Can I conclude from this that the motor controller is dead? Or am I missing something?
Colin
joan
Re: Motor controller defunct?
Fri Jan 24, 2014 4:48 pm
Check the manual. I thought the Gertboard only supported motors of more than something like 7 volts.
il_diavolo
Fri Jan 24, 2014 7:30 pm
I could be wrong but I don't think the motor supply voltage is the problem. The manual says "The motor controller is for brushed DC motors and can handle a maximum voltage of 18V and a max current of 2A". Later - "The motor will probably (not definitely) need more power (a higher voltage or current) than that provided by the Gertboard."
I tried it with 4.5V as well as 3V but still no response. I am wondering if the internal temperature "thingy" in the controller needs resetting somehow. A long shot, as far as I know it has not got hotter than ambient. Is there definitive test for checking the controller, everything else on the board works as it should.
il_diavolo
Sun Jan 26, 2014 10:09 am
Phew! Saved from embarrassment by Forum problems!
Yes, the data sheet for the controller shows a minimum voltage of 6V.
Apologies and thanks to all who replied. I achieved success with 7.5V (my 3V and 4.5V battery packs wired in series).
A case of RTFM :) :mrgreen:
Colin
Using Linux since January 3rd 2014
electronicman
Fri Jan 31, 2014 1:28 am
Be careful with the voltage, the maximum voltage for the controller is quoted at 18 Volts DC and they mean 18 volts, as I found out much to my chagrin.
David
