All leds blinking
Posted: Tue Sep 24, 2013 1:10 pm
by geirmash
Hi! I just got my gertboard and i am trying out some examples.
The example i am testing out is the one from Gordon projects.
code is as follows:
#include <stdio.h>
#include <wiringPi.h>
// LED Pin - wiringPi pin 0 is BCM_GPIO 17.
#define LED     0
int main (void)
  printf ("Raspberry Pi - Gertboard Blink\n") ;
  wiringPiSetup () ;
  pinMode (LED, OUTPUT) ;
  for (;;)
    digitalWrite (LED, 1) ;     // On
    delay (500) ;               // mS
    digitalWrite (LED, 0) ;     // Off
    delay (500) ;
  return 0 ;
When i run it, ALL the leds blink, and not only one.
I have wired up GPI17 to B1 as described.
I have the preassembled gertboard.
Is something going wrong here or am i just doing something wrong? :?
Re: All leds blinking
Posted: Wed Sep 25, 2013 9:01 am
by itsmedoofer
Hiya,
I found exactly the same thing when I tried the example..
My first mistake was I didnt read the instructions for setting up the board properly, I didnt set the power jumper or the jumpers for output, there are pics around for this if you are unsure....
Secondly when I did all this they all still lit up, however I believe this is down to the design of the board, apparently the buffers have high impedance that makes them a bit flaky unless pulled down some how...
Better explanation here:-
https://projects.drogon.net/raspberry-p ... -wiringpi/
Does say later boards shouldn't see this, I got mine beginning of September and had the issue...
Hope this helps a bit....
Posted: Thu Sep 26, 2013 1:35 pm
by alexeames
Have you put the Gertboard "On top of" the Pi or "next to" the Pi?
Posted: Thu Sep 26, 2013 11:05 pm
by itsmedoofer
Hiya,
Mine sits on top at the moment, was thinking of getting a ribbon so I can go side by side though this seems more practical. Could it be interference from the Pi causing this then ?
Should have a bread board and lots of link wires coming tomorrow so can have a proper play. :P
Cheers.
Posted: Fri Sep 27, 2013 8:20 pm
by alexeames
itsmedoofer wrote:Hiya,
do you mean like this?
Image because that is the right way round.
Posted: Sat Sep 28, 2013 7:13 am
by itsmedoofer
Hiya,
Yea got them setup like that, phew :)
Posted: Thu Dec 12, 2013 10:48 pm
by ytram99
I also say the problem of all the LEDs blinking and was rather dismayed.
Please see my two blog entries:
This one discusses the problem:
http://thepiandi.blogspot.com/2013/07/g ... -leds.html
This one discusses what I did about the problem (soldered resistors to the Gertboard).:
http://thepiandi.blogspot.com/2013/07/g ... board.html:
Regards,
Marty
