vuelosat
Touchscreen eGalax + Raspberry PI
Wed Aug 28, 2013 3:12 pm
Any one already tried the touchscreen from eGalax to work with Raspberry Pi ?
I downloaded the new Raspbian “wheezy” image and also downloaded from here the drivers:
http://home.eeti.com.tw/LinuxDriverDownload.html
I already tried those one:
eGTouch_v2.5.3120.L-x
eGalaxTouch_3.07.6014-32b
----- Some extra info:
Aug 28 14:49:09 raspberrypi kernel: [ 1295.839199] usb 1-1.2: USB disconnect, device number 4
Aug 28 14:49:13 raspberrypi kernel: [ 1299.145399] usb 1-1.2: new low-speed USB device number 6 using dwc_otg
Aug 28 14:49:13 raspberrypi kernel: [ 1299.251313] usb 1-1.2: New USB device found, idVendor=0eef, idProduct=0001
Aug 28 14:49:13 raspberrypi kernel: [ 1299.251346] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Aug 28 14:49:13 raspberrypi kernel: [ 1299.251363] usb 1-1.2: Product: USB TouchController
Aug 28 14:49:13 raspberrypi kernel: [ 1299.251377] usb 1-1.2: Manufacturer: eGalax Inc.
root@raspberrypi:/var/log# lsusb
Bus 001 Device 006: ID 0eef:0001 D-WAV Scientific Co., Ltd eGalax TouchScreen <<<- this one.
Bus 001 Device 005: ID 413c:2003 Dell Computer Corp. Keyboard
Aparently pluging this touchscreen input device USB in another PC with ubuntu 12.04.3 Lts the pointer is mouving.
I would appreciate any help installing this drivers for Raspberrypi.
itimpi
Re: Touchscreen eGalax + Raspberry PI
Thu Aug 29, 2013 9:17 am
You would need drivers that are specifically targeting the Pi version of the ARM processor, and none of those on the link you gave appear to do this. You would probably need the source code to the drivers so that they can be rebuilt for the pi.
Oakham
Thu Aug 29, 2013 9:27 am
The majority of ARM devices use ARMv7 architecture, hence the drivers support.
The Pi has ARMv6 architecture, have you searched the forum for previous postings, see:
http://www.raspberrypi.org/phpBB3/searc ... rds=egalax
Searching is easy, most questions have been asked before !
