Page 1 of 2
Usb dvb
Posted: Fri Apr 19, 2019 2:43 pm
by Mafia8540
i bought usb dvb stick rtl2832 with the new sony d2837er chip and i can not start it with dvb-c i have no drivers
where to download drivers
Re: Usb dvb
Posted: Fri Apr 19, 2019 2:51 pm
by fruitoftheloom
There is a section in this page regards RTL2832 / CXD2837 which may be worth a perusal ??
https://www.linuxtv.org/wiki/index.php/Astrometa_DVB-T2
Re: Usb dvb
Posted: Fri Apr 19, 2019 2:54 pm
by bensimmo
The new testing Linux kernel may have support in it.
Best (or easiest for me) was to use LibreElec and TVHeadend and see if it picked it up.
It also has two other methods of getting a driver.
Re: Usb dvb
Posted: Fri Apr 19, 2019 3:21 pm
by Mafia8540
I tested but I had this error http://prikachi.com/images.php?images/85/9549085z.jpg
Re: Usb dvb
Posted: Fri Apr 19, 2019 4:27 pm
by DarkPlatinum
What are you planning on doing with the DVB stick?? Aircraft tracking? Watching TV?
Re: Usb dvb
Posted: Fri Apr 19, 2019 5:42 pm
by Mafia8540
I just want to watch tv
Re: Usb dvb
Posted: Fri Apr 19, 2019 5:56 pm
by fruitoftheloom
Try the latest release of OpenElec / TV nuHeadend:
https://openelec.tv/downloads
https://openelec.tv/documentation/confi ... -tvheadend
Re: Usb dvb
Posted: Fri Apr 19, 2019 6:25 pm
by Mafia8540
this is an option but I want to use it raspbian os for other tasks
Re: Usb dvb
Posted: Sat Apr 20, 2019 10:48 am
by Mafia8540
When run "make modules_install install" its telling me
"the present kernel configuration has modules disabled"
Re: Usb dvb
Posted: Mon Apr 22, 2019 9:19 am
by DarkPlatinum
You can put the tv headon on to raspbian os and still do other things with raspbian. The tv headon is just a service, not a whole image.
Re: Usb dvb
Posted: Mon Apr 22, 2019 3:46 pm
by Mafia8540
you mean tvheadEND ?
Re: Usb dvb
Posted: Mon Apr 22, 2019 4:46 pm
by DarkPlatinum
Yes, sorry.
Re: Usb dvb
Posted: Mon Apr 22, 2019 4:48 pm
by Mafia8540
Yes, sorry.
I have a version 4.2.8-23 but he does not find it dvb-c
Re: Usb dvb
Posted: Mon Apr 22, 2019 5:11 pm
by bensimmo
TVheadend doesn't' provide the drivers so that's of no help.
Best bet is to try the latest OpenELEC and see if it works, it provides, as mentioned, additional drivers and a newer kernel whi contains a lot of newer drivers (my XBOX One TV stick for starters).
OR you could try the latest Raspberry Kernel with
sudo rpi-update
that may break your system though.
Re: Usb dvb
Posted: Tue Apr 23, 2019 12:08 pm
by DarkPlatinum
Could you provide us with a link to your DVB stick? I had a DVB stick and it was not recognized either. It depends on the quality of the device and how well it is manufactured.
Re: Usb dvb
Posted: Tue Apr 23, 2019 6:45 pm
by Mafia8540
BGN 29.40 14%OFF | Digital satellite DVB t2 usb tv stick Tuner with antenna Remote HD TV Receiver for DVB-T2/DVB-C/FM/DAB USB TV Stick FreeShipping
https://s.click.aliexpress.com/e/bvDY8YIk
on windows 10 works fine
Re: Usb dvb
Posted: Tue Apr 23, 2019 9:12 pm
by gkreidl
Even the text is misleading "Digital satellite DVB t2 usb tv stick Tuner with antenna Remote HD TV Receiver for DVB-T2/DVB-C/FM/DAB USB TV Stick ". No Satellite at all! What do you expect regarding Linux drivers?
Number 1 rule regarding DVB devices: check each item on linuxtv.org and buy only devices which are supported in the kernel.
Re: Usb dvb
Posted: Wed Apr 24, 2019 11:13 am
by DarkPlatinum
If I were you I would get a NooElec DVB-T stick from amazon.co.uk.
Re: Usb dvb
Posted: Wed Apr 24, 2019 7:00 pm
by Roken
Re: Usb dvb
Posted: Mon Apr 29, 2019 9:57 pm
by Mafia8540
any ideas?
Re: Usb dvb
Posted: Tue Apr 30, 2019 10:29 am
by DarkPlatinum
any ideas?
Return that DVB stick and buy a well known one.
Re: Usb dvb
Posted: Tue Apr 30, 2019 10:46 am
by fruitoftheloom
DVB-C ??
DVB-C stands for "Digital Video Broadcasting - Cable" and it is the DVB European consortium standard for the broadcast transmission of digital television over cable.
https://www.linuxtv.org/wiki/index.php/ ... SB_Devices
Re: Usb dvb
Posted: Tue Apr 30, 2019 11:43 am
by 6by9
Boot your Pi with the dongle disconnected.
"sudo dmesg -C".
Connect the dongle.
Post the output of "dmesg", as that is what the kernel has done in response to seeing the device.
Also post the output of "lsusb" with the device connected. Google on the VID:PID pair to see if anyone has worked on that device with Linux.
Re: Usb dvb
Posted: Thu May 02, 2019 12:55 pm
by Mafia8540
Resultat of lsusb is
  Bus 001 Device 007: ID 15f4:0131 HanfTek
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
Re: Usb dvb
Posted: Thu May 02, 2019 1:14 pm
by 6by9
So based on "15f4:0131 Hanftek", your device is an AstroMeta DVB-T2 or clone thereof, and in some variants it's supported by Linux - https://github.com/raspberrypi/linux/bl ... xu.c#L1942
See https://linuxtv.org/wiki/index.php/Astrometa_DVB-T2 for the full status, paying attention to the comment about the update in 2018. Support for the 2018 update appears to have been added in Linux 5.0, whilst we're supporting 4.19 (it is a long term support kernel). If you have a 2018 variant then you'll need to build your own kernel.
