Display turns White after toggling Backlight
Posted: Thu Nov 29, 2018 2:30 am
by SaturnsVoid
I am using one of these for my RPi3 B+ http://www.raspberrypiwiki.com/index.ph ... SKU:398437
I wrote and small script
from gpiozero import Button
from time import sleep
import RPi.GPIO as GPIO
GPIO.setmode(GPIO.BCM)
GPIO.setup(27, GPIO.OUT)
backlightON = Button(17)
backlightOFF = Button(4)
isON = True
while True:
        if (isON) and (backlightOFF.is_pressed):
                isON = False
                GPIO.output(27, GPIO.LOW)
                print "Screen OFF"
        elif (not isON) and (backlightON.is_pressed):
                isON = True
                GPIO.output(27, GPIO.HIGH)
                print "Screen ON"
        sleep(.04)
to control the Backlight using the buttons on the display, followed the examples on the wiki, But when i turn in Off and on again sometimes it turns White when its on and there is nothing on the screen.... Can anyone help me figure out a fix for this or could it just be a hardware issue???
