Just got a Pi TV hat working - so far so good.
Does anyone know what the 2-pin header on the PCB is used for that I've circled in red below...?
Is it possible to use more than 1 tuner card stacked up? Can multiple devices share an SPI bus?
Can it also receive DAB radio streams? Looking at the spec, VHF Band III is supported (174 - 230MHz) which is the same frequency allocation as DAB in the UK. If so, what software is used for that?
Has anyone managed to exploit the Sony chip as a true SDR and if so, what frequencies can it cover?
