erichabg
Which resources does the TV HAT use?
Thu Nov 08, 2018 8:12 am
Which resources (GPIO's) does the new TV use?
Or to put it another way, which GPIOs are still available for other applications?
Regards
Erich
Re: Which resources does the TV HAT use?
Thu Nov 08, 2018 8:15 am
As I understand it, it uses the SPI port and the HAT ID I2C connection and that's all.
scotty101
Thu Nov 08, 2018 9:32 am
Would be good if someone who knew what pins were used would raise a pull request on https://pinout.xyz/
6by9
Thu Nov 08, 2018 10:22 am
https://github.com/raspberrypi/linux/bl ... verlay.dts
	fragment@0 {
		target = <&spi0>;
		__overlay__ {
			/* needed to avoid dtc warning */
			#address-cells = <1>;
			#size-cells = <0>;
			status = "okay";
			spidev@0 {
				status = "disabled";
			cxd2880@0 {
				compatible = "sony,cxd2880";
				reg = <0>; /* CE0 */
				spi-max-frequency = <50000000>;
				status = "okay";
So SPI0 with CE0.
Being a HAT it will have an ID EEPROM to trigger the loading of this overlay.
