TXpiGuy
Need help with mausberry turn off circuit
Fri Oct 26, 2018 1:14 am
Hi, I'm running Retropie on my Raspberry3, and after getting a corrupted SD card from improper shutdowns (pull the cord!), I bought a mausberry turn off circuit. I attempted to follow the setup directions provided by the vendor after mechanically installing the new switch:
1. sudo wget http://files.mauseberrycircuits.com/setup.sh
2. sudo bash setup.sh
3. sudo reboot
Unfortunately, I got the following effort after trying step two:
setup.sh: line 1: syntax error near unexpected token `<'
setup.sh: line 1: `<html><head><meta http-equiv="refresh" content="0;url=http://dnserrorassist.att.net.see(window.location)+"&r="+escape(document.referrer)+"&t=0";</script></body><html>'
please note I just typed the error line above, not copy & pasted.
Does anyone have any idea what is happening? It looks like a link is not being found (dns error)? Any help would be appreciated.
Thank you
6by9
Re: Need help with mausberry turn off circuit
Fri Oct 26, 2018 6:34 am
The site no longer exists, and rather than returning the correct error your isp/dns provider is trying to return a nice web page. Unfortunately this breaks wget and it saves the error page as your file. If you had got a dns failure correctly signalled then wget would have told you the error.
You'll have to find an alternate source of that file.
TXpiGuy
Fri Oct 26, 2018 10:21 am
If I understand your answer, the vendor is selling hardware and the software to run it doesn’t exist? If so, how can I download the file in step one successfully?
RaTTuS
Fri Oct 26, 2018 10:29 am
try the contacts they may have not updated all thier site or something ?
http://mausberrycircuits.com/
https://mausberry-circuits.myshopify.com
see also
viewtopic.php?f=63&t=87491
Covfefe
TXpiGuy
Fri Oct 26, 2018 10:38 am
I have tried to contact them. I got one email asking what OS i was running, and then they went radio silent.
6by9
Fri Oct 26, 2018 10:43 am
Er, try getting the right URL
http://files.mausberrycircuits.com/setup.sh - no e between maus and berry. That file exists.
RaTTuS
Fri Oct 26, 2018 10:49 am
echo '#!/bin/bash
#this is the GPIO pin connected to the lead on switch labeled OUT
GPIOpin1=23
#this is the GPIO pin connected to the lead on switch labeled IN
GPIOpin2=24
echo "$GPIOpin1" > /sys/class/gpio/export
echo "in" > /sys/class/gpio/gpio$GPIOpin1/direction
echo "$GPIOpin2" > /sys/class/gpio/export
echo "out" > /sys/class/gpio/gpio$GPIOpin2/direction
echo "1" > /sys/class/gpio/gpio$GPIOpin2/value
while [ 1 = 1 ]; do
power=$(cat /sys/class/gpio/gpio$GPIOpin1/value)
if [ $power = 0 ]; then
sleep 1
else
sudo poweroff
fi
done' > /etc/switch.sh
sudo chmod 777 /etc/switch.sh
sudo sed -i '$ i /etc/switch.sh &' /etc/rc.local
Covfefe
TXpiGuy
Fri Oct 26, 2018 10:55 am
Just a typo here. It was a correct url when entering the command into the Pi
6by9
Fri Oct 26, 2018 10:57 am
Nope, "wget http://files.mausberrycircuits.com/setup.sh" works, as Rattus has shown as he has pasted the resulting file. Check your typing.
TXpiGuy
Fri Oct 26, 2018 10:59 am
Again, step 1 worked fine. I got the file.
Step 2 is where I get the error.
RaTTuS
Fri Oct 26, 2018 11:09 am
what is the contents of your setup.sh file
i.e.
sudo apt update && sudo apt install pastebinit
pastebinit setup.sh
or just paste it here in code tabs
Covfefe
DirkS
Fri Oct 26, 2018 11:11 am
No, you got an html file your ISP thought fit to send you because you had used an invalid URL
The correct file (which I just now donloaded myself) does not contain html tags
TXpiGuy
Fri Oct 26, 2018 11:32 am
I just tried it again, but this time the file auto saved as setup.sh.1. The ".1" addition is new.
So I went on to step 2, but used, "bash setup.sh.1" (note the .1). nothing was generated on screen, but I didn't get an error. So I went to step 3 and rebooted, then tried the switch. seems to work fine.
