jwhitmore
Multiple HATs and ID EEPROM?
Wed Oct 03, 2018 12:41 pm
I's designing a RaspberryPi "HAT" to fit onto a device which already has the RaspberryPi 7" touchscreen display. That display pretty much leaves the GPIO expansion header free for use apart from the I2C pins used for HAT Identification [1]. Now whilst I2C is can cope with multiple slave devices connected to the BUS the guidelines[1] indicate that the identification EEPROM "I2C address is 0x50". So that means that even though I can add a second HAT only one can use the ID system?
[1] https://github.com/raspberrypi/hats/blo ... gnguide.md
scotty101
Re: Multiple HATs and ID EEPROM?
Wed Oct 03, 2018 1:12 pm
There are two I2C buses available on the expansion header. One is dedicated for reading a HATs EEPROM but the other is free for you to use for what ever purpose you want.
But yes only 1 HAT can share it's EEPROM information (this isn't a great loss as so few HATs actually use the EEPROM)
hippy
Wed Oct 03, 2018 1:15 pm
Correct. If you add a second HAT, and both use the same EEPROM device address, both will likely fail to work.
The PoE HAT gets round that by using a different EEPROM device address but that is only applicable to that and cannot AFAIK be used for anything else, cannot be used to identify a second HAT.
Considering only HATs attach to those ID lines it would potentailly be possible to have the Pi check more device addresses, just as it does for identifying a fitted PoE HAT, but that's not AFAIK implemented, not part of the HAT spec, and there's no indication such a capability will be added.
jwhitmore
Wed Oct 03, 2018 7:39 pm
Thank you for the confirmation :(
I've just changed my HAT to have jumpers on it so you can disable the EEPROM, when the lines are already in use. I might look at the code which probes for attached HAT, but it probably needs a properly designed protocol between the master and the slave eeprom devices.
thanks again.
