What about https://www.buyapi.ca/product/raspberry ... aspberrypi ?
That's the one mentioned above - it's in pre-order (Aug 24 ETA)DirkS wrote: ↑Fri Aug 17, 2018 5:02 pmWhat about https://www.buyapi.ca/product/raspberry ... aspberrypi ?
Ah yes. Bit of a strange place to put that message (just below the bottom edge of my screemitchind wrote: ↑Fri Aug 17, 2018 5:05 pmThat's the one mentioned above - it's in pre-order (Aug 24 ETA)DirkS wrote: ↑Fri Aug 17, 2018 5:02 pmWhat about https://www.buyapi.ca/product/raspberry ... aspberrypi ?
I was talking about the buyapi.ca page. I could just see 'Description' at the bottom of my screen and did not expect essential availability information there
When the fan first starts there seems to be a bit of a grating sound, this settles down after initial spin up of the fan, so im hoping i can have the fan run on its lowest setting to avoid the constant start stop cycle.ShiftPlusOne wrote: ↑Sat Aug 18, 2018 2:58 pm
Yes, you have full flexibility here. What behaviour do you want from it?
Would you like it to just constantly have the same slow speed and not adjust according to CPU temperature.Stuart-JW wrote: ↑Sat Aug 18, 2018 3:21 pmWhen the fan first starts there seems to be a bit of a grating sound, this settles down after initial spin up of the fan, so im hoping i can have the fan run on its lowest setting to avoid the constant start stop cycle.ShiftPlusOne wrote: ↑Sat Aug 18, 2018 2:58 pm
my pi temp is between 44.5 and 45.1. seems to kick on at 45 degrees, so every few seconds it starts, spins for a few seconds and stops. its not excessively loud, but its quite close to me.
I might make a longer cat 5e cable and hide it in a cupboard somewhere,![]()
I don't have it here, so I'm going off memory. There may be some mistakes.
nightwatchman wrote: ↑Sat Aug 18, 2018 4:46 pmHello!
I received my Pi 3B+ PoE HAT for 2 of my Pi's from RS yesterday, installed fine, turned on, updated the OS to get the latest Kernel, did a cold boot, and everything is going fine powering them from my Switch. Fan is on and off quite often...but that's fine.
However...
2 issues I have noticed.
1) On my first Pi. I have a small USB 3-based hard drive, just a small portable one, and that is the only thing plugged in. For some reason, the Pi just doesn't appear to be giving it stable enough power, as that drive keeps constantly disconnecting and reconnecting (I hear it clicking on and off all the time). It powers up, only to power back down 5 seconds later. So that all it does. I have tried the same with a simple, low power USB flash drive, and that too just constantly connects and reconnects; its LED just keeps flickering.
2) On my second Pi. For some reason, the Pi's red power LED sometimes goes off for about 6 seconds , the comes back on again where it will be okay for a few minutes, and then it'll go off again. It looks like the HAT is still being powered at this point, just my Pi board loses power.
I was running both Pi's on their officlal 5V 2.4A power supplies before I got the PoE HAT, and these problems have started since I got the HAT! It's worth noting that these are brand new Pi's with their official PoE HAT now attached to them; there's nothing else connected.
So I'm wondering if anyone else is seeing what I'm seeing with the red power LED turning off, or having issues with USB devices not getting enough power when using the PoE HAT?
Thanks.
