saucompeng
New 3G-4G/LTE Base Shield is available for preorder!
Tue Oct 17, 2017 8:56 am
This is the newest version of our Raspberry Pi 3G – 4G / LTE Base Shield, the smallest, most easy-to-use, and most versatile Cellular Communication Shield we ever designed.
http://sixfab.com/product/raspberry-pi- ... pre-order/
-There is a clip-in Mini PCIe socket for your communication need.
-With the 4G/LTE Module(EC25) you can reach 150Mbps downlink and 50Mbps uplink data rates and the 3G Module(Quectel UC20) delivers the maximum data rate of 14.4Mbps downlink and 5.76Mbps uplink, and – The modules have built-in GPS/GLONASS for your location-based applications.
-The modules of different regions&frequencies are in stock. You’ll need the get the compatible module with your region or carrier. Let us help you to while choosing the right module if you need: hello@sixfab.com
You can power the shield via Micro USB or external 5V sources can be soldered. So, you can use the different batteries or power sources as you need.
-The Micro Sim Card socket can easily reachable on the upside of the shield.
-The shield is fully compatible with the single 40-pin expansion header of Raspberry Pi. With the 55 x 65mm dimensions, the shield is a perfect fit for Raspberry Pi.
-The shield can be used standalone with your PC/Laptop over Micro USB, without stacking with Raspberry Pi.
You will get the special designed Micro USB cable- as you see on pictures- as a gift.
The Differences Between Old Version:
-%25 smaller
-No more need to screwing modules to shield. Thanks to the clip-in Mini PCIe socket, it’s more fun to mount the module on the shield.
-The Sim Card Socket is a Micro Sim Card Socket now, and it’s on the upside of the shield.
-The new power regulation circuit is more efficient and optimized so it’s cooler than old version while working.
-No more bulky DC-Barrel Jack! The power input of the shield is 5V and can be obtained via Micro USB or power pins.
oscramgon
Re: New 3G-4G/LTE Base Shield is available for preorder!
Fri Oct 05, 2018 9:10 pm
I have purchased Raspberry Pi Cellular IoT Application Shield – LTE-M & NB-IoT & eGPRS, and going through instructions in web I have been able to send UDP message. Now I am trying to configure Shield and Raspberry Pi to be able to open a socket TCP and send messages to server. I can do that with Raspberry Pi and LTE telephone giving access to raspberry pi throught LTE phone server, and, on this way, I can see an interface in my Pi with command ifconfig. I was wondering if it would be possible make same config: have an interaface in raspberry pi towards Shield, that permit make ping from Pi console and open TCP sockets and send/receive messages to server.
Thanks for help
Oscar
