szekla
gps not working
Sat Sep 22, 2012 3:52 pm
Hello everyone
I cannot get cgps display GPS output
I have installed gpsd, gpsd-clients, python-gps packages
I am using holux m 215 gps receiver that identifies itself with lsusb as 10c4:ea60 Cygnal Integrated Products, Incorporated. cp210xUart bridge
when I look up the dev catalogue there is a file called @gps0
therefore I try to run
pi@raspberrypi:~$ sudo gpsd /dev/gps0 -F /var/run/gpsd.sock
then I try
pi@raspberrypi:~$ cgps -s
sadly there is no communication with GPS. After a second or so, there is a timeout message from cgps.
Any ideas?
elatllat
Re: gps not working
Wed Sep 26, 2012 4:30 pm
only time I used a gps with linux I used setty on the /dev/tty-gps-or-whatever
then was able to cat the data off the /dev/ttygpsow
SBC with 32GB RAM: https://hardkernel.com
FAQ : https://raspberrypi.stackexchange.com
Unanswered: https://www.raspberrypi.org/forums/search.php?search_id=unanswered
pjac
Re: gps not working
Mon Oct 22, 2012 10:47 pm
I found restarting gpsd could help - this was using a USB-serial Microsoft GPS-360 dongle (blog post).
cdaaawg
Re: gps not working
Wed Jan 09, 2013 7:12 pm
I get the same timeout problem when running cgps. Also, xgps doesn't seem to be receiving data from gpsd. However, when I run
gpsmon /dev/ttyUSB0
correct time and location data is displayed.
sonicvanajr
Re: gps not working
Wed Apr 24, 2013 4:18 am
The trick to this is to pass the "-n" flag to gpsd.
-n
Don't wait for a client to connect before polling whatever GPS is associated with it. Some
RS232 GPSes wait in a standby mode (drawing less power) when the host machine is not
asserting DTR, and some cellphone and handheld embedded GPSes have similar behaviors.
Accordingly, waiting for a watch request to open the device may save battery power. (This
capability is rare in consumer-grade devices and nonexistent in USB GPSes which lack a DTR
line.)
lyonzy
Re: gps not working
Sat May 25, 2013 2:31 pm
@sonicvanajr you're a genius - works a charm :)
thijsjek
Re: gps not working
Sat Jun 22, 2013 7:18 pm
sonicvanajr wrote:The trick to this is to pass the "-n" flag to gpsd.
-n
line.)
Hey Sonicvanajr,
It helped me too, Thanks a lot!
paddi2013
Re: gps not working
Thu Jul 25, 2013 7:05 am
" $ sudo gpsd /dev/ttyAMA0 -F /var/run/gpsd.sock "
Where exactly should I put the "-n" ? Please and thank you
joan
Re: gps not working
Thu Jul 25, 2013 7:51 am
Most programs don't care about the order of options.
Use
man gpsd
to check if gpsd does.
paddi2013
Re: gps not working
Mon Jul 29, 2013 7:48 am
thx man, appreciate it :)
BuryMisiek
Re: gps not working
Sat Dec 21, 2013 11:11 am
For me that fix didn't help. If i try to:
gpsd /dev/ttyUSB0 -n -N
I'm getting
gpsd:ERROR: can't create IPv6 socket
gpsd:SHOUT: vendor/product match with 091e:0003 not found
gpsd:ERROR: PPS ioctl(TIOCMIWAIT) failed: 25 Inappropriate ioctl for device
gpsmon works fine and I'm getting data. Some ideas about that ?
koza
Re: gps not working
Sun Dec 13, 2015 2:46 pm
Hello Guys,
I know topic is old, but maybe I can help someone in the future.
I have USB GPS (HOLUX 215) and Raspbian. To make it work, I had to go through the following steps.
STEP 1:
Install drivers:
sudo apt-get install gpsd gpsd-clients python-gps
STEP 2:
then run daemon gpsd
sudo gpsd /dev/ttyUSB0 -F /var/run/gpsd.sock
(not needed in my case! it was automatically added to the processes - you can check if it is a case in your case with ps -ef, also -n is not needed with USB)
and then
cat /dev/ttyUSB0
didn't return any results (nor my custom application in C).
STEP 3 - solution:
The solution is (after 5 hours of debugging...) that the serial port speed is not properly set. To set it, type:
stty –F /dev/ttyUSB0 4800
Hope I will help someone with this small simple command :).
Greetings from windy Warsaw, Poland!
Koza
paulbirch
Re: gps not working
Tue Jan 19, 2016 10:18 am
Hi
Although old thread I get the same issue
BU 353 GPS via usb
gpsmon gives me lots of data
I have tried the -n flag and started undaemonized
pi@mrreese:/dev/serial $ sudo gpsd -n -N -D3 -F /var/run/gpsd.sock
gpsd:INFO: launching (Version 3.11)
gpsd:INFO: listening on port gpsd
gpsd:INFO: running with effective group ID 20
gpsd:INFO: running with effective user ID 110
gpsd:INFO: startup at 2016-01-19T10:12:46.000Z (1453198366)
when I start cgps -s on another terminal session gpsd gives me
gpsd:CLIENT: => client(0): {"class":"VERSION","release":"3.11","rev":"3.11-3","proto_major":3,"proto_minor":9}\x0d\x0a
gpsd:CLIENT: <= client(0): ?WATCH={"enable":true,"json":true};\x0a
gpsd:CLIENT: => client(0): {"class":"DEVICES","devices":[]}\x0d\x0a{"class":"WATCH","enable":true,"json":true,"nmea":false,"raw":0,"scaled":false,"timing":false,"split24":false,"pps":false}\x0d\x0a
cgps stops on the terminal after 4-5sec with
cgps: GPS timeout
and gpsd comes back with
gpsd:INFO: detaching ::1 (sub 0, fd 7) in detach_client
I have tried setting speed of ttyUSB to 4800 and other speeds
any help really appreciated
SonOfAMotherlessGoat
Re: gps not working
Wed Jan 20, 2016 6:55 am
What messages do you get if you increase debug level from 3 to 5?
Account Inactive
ayrton88
Re: gps not working
Wed Feb 22, 2017 4:29 pm
I have the same issue, I tried everything in this page but nothing really worked.
When I run the
sudo cat /dev/ttyUSB0 I dont get any data either
I have tried to connect it using the UART too, but that didnt help either.
Any ideas?
dloranger
Re: gps not working
Fri Jun 09, 2017 5:43 pm
I too was fighting with the GPS (mine comes through on the serial port), I could not get cgps -s, or gpsmon to see any birds.
Found this https://learn.adafruit.com/adafruit-ult ... i/use-gpsd
which has the following nuggets that got everything up and running for me
sudo systemctl stop gpsd.socket
sudo systemctl disable gpsd.sockett
followed by relaunching gpsd with the settings you want
note I changed ttyAMA0 to use the "serial0" or "serial1" as recommended (forget where but I discovered that yesterday trying to figure out the serial port stuff) for compatibility between pi hardware revisions.
There is also this that describes using the PPS signal for higher accuracyhttps://forums.adafruit.com/viewtopic.p ... 60#p359668
hope this helps someone
PiNambiAgas
Re: gps not working
Thu Mar 08, 2018 7:50 pm
Hello All,
Really needed help! cygnal integrated products GPS is always showing NO FIX!
pls help me out I got to do this
ripperon
Re: gps not working
Tue Jan 22, 2019 3:06 am
I can solve with this.
First take out the GPS on my window after that change the voltage from 3.3V to 5V and wait for connect to satelites
I did use the gpsmon for monitoring
