roycork
PIFACE RELAY PLUS
Mon Oct 10, 2016 10:10 am
Hi
We are doing a project, we have set up using a piface relay plus to control pumps BUT!! it seems piface relay plus no longer available on farnell?
Anyone have any news about this or an alternative device or a source where we can buy a few from?
Roy
BMS Doug
Re: PIFACE RELAY PLUS
Mon Oct 10, 2016 10:19 am
this Pi relay base may be suitable, but be aware that it's quite a bit bigger than the pi footprint.
Doug.
TonyD
Mon Oct 10, 2016 11:27 am
Tony
roycork
Fri Nov 18, 2016 1:09 pm
Thanks for this, I was told it has to be the piface relay plus
I wonder what is going on with Piface, does anyone know, they stopped replying
http://www.piface.org.uk/products/piface_relay_plus/
Bruce_Pi
Thu Feb 23, 2017 4:54 pm
You can look into an I2C relay shield with a solid state relay controller.
something like this
https://shop.controleverything.com/coll ... controller
if you are using this to control pump I will suggest going with a solid state relay controller. the main advantage of using off-board solid stat relay controller is that it will keep your Pi safe from all kinds of noise and back emf.
roycork
Thu Feb 23, 2017 5:41 pm
Thank you very much
We ended up designing our own pi hat with everything on it, just need to sort out power now, we have to power the pi screen, the pi and the pumps, at the moment we have 3 separate power supplies
Roy
