digger72
Pi Zero Hub Without Cable or Connector with integrated Wifi
Tue May 10, 2016 1:46 am
Last week I designed and released board that I call HubPiWi - basically a hub without any cable or connector. It connects with the Pi Zero with Pogo Pins.
The key aspect of this board is the integration of Wifi using one of the 4 USB ports. So this board will give 3 USB port and a Wifi.
All this while not requiring and cable or connector.
You may find the details of this board at
https://www.kickstarter.com/projects/17 ... o-cable-c/
Would like others feedback on this.
typxxi
Re: Pi Zero Hub Without Cable or Connector with integrated W
Sun May 22, 2016 8:54 am
Great idea and very good iteration of your previous project - that 4 usb hub.
Unfortunatelly sold out but propably it won't make sense to produce another charge if the next generation is coming.
I hope more will pledge for that great product.
I like that I do not have to solder. Forget all the headache of previous solutions when headless did not work anymore ...
Good luck.
WOLF
