gordon77
Pi Relay and i2c question
Fri Nov 27, 2015 2:21 pm
I see plenty of threads about people struggling with interfacing relays, this may help.
http://www.amazon.co.uk/Raspberry-Pi-Re ... B00WA857JY
( I wouldn't recommend switching mains with it )
BMS Doug
Re: Pi Relay
Fri Nov 27, 2015 2:55 pm
gordon77 wrote:I see plenty of threads about people struggling with interfacing relays, this may help.
The separation looks pretty good, I'd want to test it (to destruction if necessary) with an insulation resistance test meter before sticking it on mains.
Doug.
gordon77
Re: Pi Relay
Sun Nov 29, 2015 3:11 pm
I've been looking at using one of these but I am confused by i2c.
I am using Raspbian & Jessie and have an RTC which is configured by adding 'dtoverlay=i2c-rtc,ds1307' in /boot/config.txt.
Is this using i2c-0 or i2c-1 or maybe neither ? as the relay needs 0 or 1.
It uses bus=smbus.SMbus(1), where 1 = /dev/i2c-1 or 0 = /dev/i2c-0
and with the RTC how is i2c working when 'dtparam=i2c_arm=on' isn't enabled in /boot/config.txt ?
Gordon
Tage
Re: Pi Relay
Sun Nov 29, 2015 4:34 pm
there is practically no distance between power traces and the pins that connect to the coil which means that if you connect it to mains voltage you have a very dangerous situation.
