pi3g
Authorised Reseller
Authorised Reseller
Re: SD card sticking out ? Use RSMMC
Sun Mar 10, 2013 5:35 pm
For the lead to connect an external SD adapter: You would have to take into account that timing is critical on high-speed data applications.
I had a customer exchange a (mechanically) broken SD slot with a new one I obtained for him on the Raspberry Pi, and it stopped booting from it - maybe something went wrong while soldering, maybe there are some timing problems ...
But - no one is stopping you from trying!
picockpit.com - tools to make your life with the Pi a little bit easier
exartemarte
Sun Mar 10, 2013 8:28 pm
pi3g wrote:I had a customer exchange a (mechanically) broken SD slot with a new one I obtained for him on the Raspberry Pi, and it stopped booting from it - maybe something went wrong while soldering, maybe there are some timing problems ...
I have done a couple of these without too much difficulty: details here.
Those are my two static Pi's - I also have a couple of non-static Pi's, one mounted with a breadboard and one being built into a mobile robot, which still have the original card sockets. These have the ModMyPi micro-SD carriers and I have found them excellent. A downside, though, is that they stand slightly proud of the socket, which is a problem if you have a tight-fitting case; I had to modify a couple of mine:
According to ModMyPi their case will accommodate the adapter. I tried it in a version 1 ModMyPi case and found I could close it, but the Pi sat at a slight angle. Maybe ModMyPi built some extra space into their version 2 case.
It was suggested in an earlier post that it might be better if the micro-SD slot opened to the side. The AdaFruit one does, but it doesn't seem to be available in the UK and postage from the States adds significantly to the price.
thexeno
Sun Jun 02, 2013 2:37 pm
Hi! I'm sorry if I pick-up an old post, but seems what I'm looking for :)
I've a Kingston Dual-Voltage MMC mobile 2GB and I still don't understand why it's not recognized by the PI. At power on, the ACT led flashes 3 times. The error code means that .elf file is not found (http://elinux.org/R-Pi_Troubleshooting# ... ic_pattern)
Someone said that is why there's no more support for MMCs. But it's for sure? Can someone saying the opposite?
johnlane
Tue Jun 18, 2013 1:33 pm
I found a 64MB RS-MMC card in a drawer. I thought "great, use it as a boot drive - everything else is on the hdd anyways". I prepped the card but it doesn't boot - same old three flashes routine. It isn't the prepping that's bad as I also tried it on a (smaller) SD card I had lying around.
It's a shame they don't work. To boot I don't need a fast large capacity card so on the surface using these old RS-MMC cards seemed ideal. They get the card flush with the board and reduce the likelihood of catching an inserted card and breaking the slot.
If anyone knows a way to make one of these boot (perhaps using old firmware files?) I'd be interested...
Raspberry Pi Utilities: https://github.com/johnlane/rpi-utils
For Raspberry Pi and Arch Linux
PiGraham
Sat Jul 13, 2013 7:32 am
podly wrote:
wolfgangmob wrote:Another option is a combo adapter for micro SD to SD/USB then just cut off the USB side of the adapter.
What do you mean? Any links to this kind adapter?
cheers,
http://rolandsoft.blogspot.co.uk/2012/1 ... crosd.html
IseMan
Sat Dec 21, 2013 7:37 pm
Not sure if anyone is still interested or if I missed this being posted (reading on an iPhone) but I found this and am rather tempted to try it...
http://www.amazon.com/gp/aw/d/B00AKO3EVS
exartemarte
Sat Dec 21, 2013 11:20 pm
IseMan wrote:Not sure if anyone is still interested or if I missed this being posted (reading on an iPhone) but I found this and am rather tempted to try it...
Looks like the Adafruit one - on the Adafruit website it's only $5.95.
