zoelqivlie
7 Inch lcd resolution
Tue Dec 23, 2014 5:24 pm
Hi, I have a 7 inch LCD with Controller Board Kit, they are connected by TTL Signal 50 pins but I can't get fix resolution, I've changed some parameters in config.txt but no improvement, any can help me? thank you and sorry for my english ;-)
tkraspilabs Indonesia | Pi 512M Rev 2 | Pi B+ | Pi 2 B | Pi Zero | Pi 3B
DirkS
Re: 7 Inch lcd resolution
Tue Dec 23, 2014 6:01 pm
So you're using RasPi's HDMI out to connect to your screen?
First try removing every single setting related to HDMI, screensize, etc, and start the Pi
Run 'tvservice -m DMT' should give you the modes that are possible (as far as the Pi can tell) and a preferred mode.
Compare this with the LCD's capabilities.
Gr.
Dirk.
mikronauts
Tue Dec 23, 2014 7:19 pm
That displays native resolution is almost certainly 800x480
try to force that resolution on the Pi.
