Transparent RS232 pipe
Posted: Sat May 10, 2014 2:05 pm
by Richard-TX
I need to create a transparent rs-232 connection from my pc to a remote device. I thought that the Rpi would be a good solution.
I need to connect the serial port on the PC to a Rpi which then connects to a remote Rpi over wifi and then out the remote Rpi's serial port. This needs to act like a piece of wire from end to end.
Here is a simple diagram
PC -> rs232 -> Rpi-> WIFI -> Rpi -> rs232 -> remote device
Any ideas on how I can accomplish this?
Richard
Re: Transparent RS232 pipe
Posted: Sat May 10, 2014 2:14 pm
by ame
Netcat?
Posted: Sat May 10, 2014 2:23 pm
by msperl
Sercd in conjunction with xinetd allows for a tcp-socket to get connected to a serial port. That should be mostly sufficient.
Posted: Sat May 10, 2014 2:35 pm
by elektrknight
Serial port to network proxy aka ser2net http://sourceforge.net/projects/ser2net/
See this page "Raspberry Pi + ser2net = Cheap NM16A (Serial Console Server)" http://lesser-evil.com/2013/04/raspberr ... le-server/
Cheers,
elektrknight
Posted: Sat May 10, 2014 2:38 pm
by elektrknight
And one more: serialoverip - "Serial Over IP" http://sourceforge.net/projects/serialoverip/
Just found it so no idea how well it works.
Cheers,
elektrknight
Posted: Sun May 11, 2014 2:25 pm
by klricks
+1 ser2net
I have detailed setup instructions here:
http://home.budget.net/~klricks/Comp/RPi/Serial.html
