Anxious
Question: I2C, How much do the hardware drivers do?
Tue Dec 11, 2012 6:17 pm
So, I don't have the best oscilloscope around so I am very limited in cheking the IC2 Signals I will get.
I plan to connect a device which uses NMAK and MAK aswell as the usual AK ( Not Master Acknowledge , Master Acknowledge, Acknowledge )
So I want to ask: Do I write the Acknowledge to the port by myself with the write function of temios.h or is that beeing done by the driver. Aswell as, do I need to take care of MAK or NMAK or will the driver do that for me?
Additionally, My I2C Device I want to communicate with demands another Start condition after the Sub Adress. ( It uses a master address for device identification and sub address for register identification ). How can the PI I2C Device produce such? Can I utilize termios.h ?
Im sorry It didnt take long enough for someone to reply. But atleast you will have it in your archieves now.
I found the solution over here: http://scummos.blogspot.de/2012/11/rasp ... start.html
clicky
Re: Question: I2C, How much do the hardware drivers do?
Fri Dec 14, 2012 3:38 pm
I've just checked the link you gave briefly and didn't get most of the answer you were looking for. Would you mind summarising what you learned from that blog in here?
